Results 1 to 10 of 13
Thread: Crazy ground loop- is isolator safe?
    107 is offline
    Aug 2004
    I just finished installing my CarPC and I get a lot of noise when I connect it to my DSP accompanied by my Xenarc screen getting fuzzy/wavy. There is no noise caused by the PC when the audio is not connected.
    I'm assuming this is a ground loop issue and hope to fix it with an isolator. Assuming the isolator fixes the noise, will it be safe on my audio equipment?
    I have an old Rockford Fosgate Symmetry 2 connected to my head unit and two amps(and now the CarPC). The Symmetry and Amps are grounded to the trunk, while the CarPC is up front grounded to a factory ground(where the cig. lighter used to be).
    Any suggestions on how to fix the problem if the isolator won't work? I can't use an external USB soundcard because I am running an advantech 5.25" form factor PC with a 90W Opus and am having voltage issues with my 5 attached USB devices as is.
    FLAC ppgt94's Avatar
    May 2001
    USA
    Most ground loop isolators are made to go in-line of the audio RCA cables. I would guess they are safe. I haven't tried any yet though. I have a ground loop as well. Sucks.
    Constant Bitrate nirvanades's Avatar
    Find better grounding points. Don't use factory ground wires - run your own.
    2003 Chevy Tahoe Z71
    STOLEN - M10000, 512MB, 60GB 2.5" HDD, 7" Custom mounted Lilliput, Morex 3688 Case, 90W PSU w/ ITPS, GPS & CD-RW/DVD. New parts ordered for the next generation!
    107 is offline
    Aug 2004
    Yeah it does suck, right when I thought I was done- had it all working perfectly outside the car, I put it in and have 3 major problems... This being one of them! I have my own ground wires on everything except the PC. I've spent so much time on this thing I'm about to toss it out the window- about 2x budget and a lot more time than I thought, the novelty has worn off! I will try the isolator first, and if need be I will run my own ground wire- but the PC is so far away from my amps I'm afraid I would have a ground loop even if I did that.
    May 2001
    USA
    You should have only one ground point, if possible. You can then then daisy chain from that ground point if you need.
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    ground loop isolators are safe but i have heard they degrease some of the sound quality, this isnt speaking from experience tho i have never used one
    Signature: [==||========] 20% complete
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Nic is right. You should avoid them at all costs. They are completly safe although they may degrade you sound quality and are frowned upon by most car audio sound fanatics. They are essentially a bandaid to the greater problem. I say just out of moral reasons fix the problem and don't put a bandaid over it. Also search this forum. I have offered many troubleshooting tips to others having noise problems.
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    I agree. Most audio noise issues are caused by grounds having different lengths of travel. If you ground them all at the same point, that should do it.
    Tidder
    Try RevFE
    Jan 2004
    California
    Quote Originally Posted by Tidder
    It is not the length that effects it (well it does but indirectly) it is the resitance or impedance of the wire. Theoretically all of your grounds should have 0 impedance. We all know that is not true to real world situations so a low impedance of 25 milliohms is good. The point is the get all of you grounds at similar impedances. That will eliminiate componants grounds traveling extended unfortunate routes that cause your ground loops
    Aug 2004
    Ottawa, ON, Canada
    I just installed a ground loop isolator tonight, i've been playing with grounds for 2 weeks and just couldn't make the noise go away, after installing the isolator, all noise is gone and I couldn't be happier. I did so much troubleshooting i felt like tossing the whole lot out, why didn't i buy that 2 weeks ago?
    My and my buddy do car audio stuff all the time, but we could not get rid of this ground loop.
    I wouldn't worry too much about sound quality, i couldn't even notice a difference. Now if your building a strict SQ system, then i'd say don't use it.
    It is a band aid, but it works for me. I may try in the future to solve the real problem but for now it's nice to hear clear sound from my carputer!
    Best $20 I ever spent!
  1. Ground Loop
    By Twiek in forum General Hardware Discussion
    Last Post: 03-12-2004, 01:20 AM
  2. Turtle Beach Santa Cruz Sound Card GIVES me a ground loop?
    By rmjjensen in forum General Hardware Discussion
    Last Post: 11-15-2003, 08:26 AM
  3. FS: Radio Shack Ground Loop Isolator!
    By mwinkler in forum Classified Archive
    Last Post: 04-11-2001, 11:38 PM
  4. ground loop isolator help
    By digital chaos in forum General Hardware Discussion
    Last Post: 03-11-2001, 02:38 AM
  5. Where does ground loop isolator install?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 09-14-2000, 09:10 AM
