WooWoooo!
I'm aware that this is very vague, but I was wondering...
I just installed my subs and amp into my '91 accord (I swear, that car is pimp-able), and after about a minute of pretty loud playing, I got a melting/burning smell..Also, my 'seatbelt-unfastened'* light flicked a bit. I went home and checked everything, and found no problems. No wires were too hot, nothing had burned, it was all good. Later that day, I turned it up again, and I didn't get a burning smell, but I got very warm air out of the vents (warmer than usual). The AC was not on. My first guess was the alternator, checked that out, and with the AC off, I still got about 14 Volts across the terminals.
Right now, I'm not too concerned about it, but I figured it wouldn't hurt to ask around if anyone had encountered anything similar. I'm totally blank on what the problem is. I'm using a monster wiring kit, 8 gauge, which is what my amp says it needs.. Any ideas ?
Tell me if you need something clarified.
*: actually my battery light
WooWoooo!
www.i-hacked.com Hardware hacking articles
Ur right ! that is helpful !![]()
I consider that our present sufferings are not worth comparing with the glory that will be revealed in us.
www.neoterikos.com
actually its
WooWooo!
and did you check all your fuses?
what kind of amp?
are you confident with your installation abilities?
rebuilding carpc... kinda..
fuses are good
amp is a crunch PZN-2250 250 x 2 watts
I know little about car stereos, but dad has a major in electical engineering....
I was raised believing that meant something..![]()
www.neoterikos.com
it might just be your car dying.
o ok good
www.neoterikos.com
got it you only let some of the smoke out of the wiring -- keep going so you let the rest of that bad smoke out and YOU WILL find out what went wrong
go to sears and get a optical temp prob find the hot harness-- then fix befor you have a fire .
http://www.infrared-usa.com/default.asp?param1=overture
I didn't really understand that, but it sounded like a bad idea.. so explain further if its an idea worth being heard
www.neoterikos.com
run the amps for a short (non damaging ) amount of time. then use the temp prob to check the temp of suspected wiring-find a hot harness- then follow that to the source of high load. i use this a work to find melfunctioning componets in cars. i am a mitsubishi/nissan master tech, this help to find a cuciut that is not shorted but has a high draw.
