Results 21 to 30 of 31
Thread: Tube Subwoofers...
  1. #21
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    actually to tell you the truth, I did test it with water, look at the third pic, there is a little water stain. I know not a smart idea. But to seal it compeletly I will use some caulk, just to be sure.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  2. #22
    Newbie Redeyez's Avatar
    Oct 2004
    San Antonio
    MAKE SURE U HAVE TONS OF SUPPORT!!!! my big brother's friend built a casing kinda like that, with partical board. it cracked then shattered into like 20 peices. Be warned
  3. #23
    Dec 2003
    New York
    Quote Originally Posted by Redeyez
    Thats your problem right there, partical board. I didn't use that, I used mdf board, which is stronger and better suited for enclosure construction. Plus I think I have plenty layers of fiberglass, I don't think it's about to shatter anytime soon, atleast I hope not.
    Installed
  4. #24
    Aug 2004
    im a pro sound monkey
    tub subs were big a couple years ago
    primarily because you could build 4th/6th/8th order bandpass boxes easily and effectivly.
    beuase you already have the tube you only need to cut the "caps" to the tube
    so this reduced the labor involved in construction greatly.
    as long as the math is right it will sound fine
    the ideal box is a trapazoid, with no parrallel sides and no 90* angles,(eliminates standing waves) basically a ***** to build. the tube gets around this nicely. at least better then a square/rectangular box
  5. #25
    Aug 2004
    MDF = pretty good
    but you know your awesome when you use Baltic Birch
  6. #26
    Tainted Love Cris's Avatar
    Romania
    Quote Originally Posted by MetalDwarf
    So you're saying , this trapezoidal box, would sound much nicer than a tube?
    I have a tube in my trunk, and it sounds very nice.
    And what's Baltic Birch?
  7. #27
    Dec 2003
    New York
    Yeah, baltic birch would be really good to use, but your price to build the enclosure triples.
    Installed
  8. #28
    Variable Bitrate danon's Avatar
    Oct 2003
    Queensland, Australia
    Quote Originally Posted by Quattro-A4
    mdf bloat when in contact with water. even when dried afterward it does not retain its original size. how did you go on with it?
    [....99.9%]
    [HW] 566eMHz/128mb/6gb, FlyVideo3k, RandMgps, M1-ATX, 7" Lilliput, VGA2AVadptrFor2ndVideo, 4CH/100rms, 10"Sub, 40AhDeepCycleTank
    [....99.8%]
    [SW] XP/MMC/FP:D3,FlyTV/AxifeFM,CarMM?
    [Working on] puttingBackEvrythg.
  9. #29
    Dec 2003
    New York
    The mdf board is not bloated or deformed in any way. There is just a little water stain. The board is still really strong, it doesn't appear to be weak in any way. So, I hope I don't have any problems with it.
    What do you mean by 'how did you go on with it?'
    Installed
  10. #30
    Variable Bitrate lawrence's Avatar
    Oct 2003
    carol stream illinois
    metal dwarf i am new to building sub boxes ,could you explain the differences in 4th/6th/8th order bandpass ?
  1. Sound Vibrations from Subwoofers
    By Bendold in forum General Hardware Discussion
    Last Post: 10-27-2004, 01:24 AM
  2. Replies: 0
    Last Post: 09-18-2004, 02:40 AM
  3. Opinions of tube subwoofers?
    By King_Xerxes in forum General Hardware Discussion
    Last Post: 06-06-2002, 05:21 AM
  4. Small enclosure subwoofers
    By marsjell in forum General MP3Car Discussion
    Last Post: 02-05-2002, 06:51 PM
  5. Subwoofers and computer----
    By TimW in forum General Hardware Discussion
    Last Post: 07-21-2000, 09:12 PM
