Page 2 of 12 FirstFirst 1234567891011 ... LastLast
Results 11 to 20 of 111
Thread: What's up with my BRAND NEW speakers??
  1. #11
    Maximum Bitrate brrman's Avatar
    Aug 2003
    Indianapolis, IN USA
    an amp at 50-100W/channel rms is fine for your speakers. Even a cheap one - you don't need anything monstrous or high end brand name. Hifonics makes a good amp in that range and at a good price.
    http://cgi.ebay.com/ws/eBayISAPI.dll...724311982&rd=1
    Car: 2000 Audi A4 Avant 1.8t
    Carputer 2.0: removed. Back to stock.
  2. #12
    Low Bitrate Aksor's Avatar
    Mar 2004
    Ottawa, ON
    From personal experience I know that most head units start to clip pretty badly at 3/4 volume. I actually tested a few using a test CD and monitoring the output with a scope.
    Each time the sine wave clips (flattens out) the speaker is actually receiving a constant voltage that turns the coil into a heater and blows your speaker.
  3. #13
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    So I should be getting a 4 channel amp right?
    And what about hooking it up?
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
  4. #14
    Oct 2003
    Poland, OH
    Quote Originally Posted by Aksor
    So they could be blown already?
  5. #15
    Maximum Bitrate Snootch's Avatar
    Sep 2003
    Tampa, Florida
    You only need a 4-channel amp if being able to fade front/rear is important. If not, you can run all 4 speakers with a stereo (2-channel) amplifier. About buying amps... I've bought 5 amps used off Ebay, and havent had a problem. I would stick to proven amps (old-school fosgate, PPI or Orion) and only buy from people with a high feedback rating. Here's some good 4 and 2 channel 50 watt per channel RMS amps Ive found for you:
    http://cgi.ebay.com/ws/eBayISAPI.dll...725114918&rd=1
    http://cgi.ebay.com/ws/eBayISAPI.dll...725114956&rd=1
    http://cgi.ebay.com/ws/eBayISAPI.dll...725499724&rd=1
    http://cgi.ebay.com/ws/eBayISAPI.dll...725125537&rd=1
    http://cgi.ebay.com/ws/eBayISAPI.dll...724789381&rd=1
    http://cgi.ebay.com/ws/eBayISAPI.dll...725131200&rd=1
    http://cgi.ebay.com/ws/eBayISAPI.dll...725261411&rd=1
    Good luck!
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
  6. #16
    Oct 2003
    Poland, OH
    So if I bought a 2 X 100 amp and I hooked up all 4 speakers to it would I essentialy be giving them only 25 W each?
    And should I be looking for a 4 ohm?
  7. #17
    FLAC sdashiki's Avatar
    Aug 2004
    Floreeda
    Then you are taling bridging and OHM resistance. When it comes to the 4 speakers in yer car (8 for us audiophiles) DONT BRIDGE THEM. A 2 channel amp runs either 1 or 2 speekers, not 4. Yeah of course you can but for our purposes, I wouldnt. I wont get into Ohmage and all that crap but basically an amps # of channels shouldnt be exceeded unless it is said to be LOW OHM STABLE.
    I personally LOVE 5 channel amps when you dont want to be a $$$$ f*er and have 1 amp for every speaker and like 4 batteries to run it. For people who actually drive their cars to work, school, food etc, a competition sized audio system is very impractical. The basic rule of thumb IMO is that u buy a 4 channel amp to run your regular door speakers, and a 2 or 1 channel to run your 1 or 2 or even 3 or 4 subs. Subs run different than full range speakrs, and the OHM loads are much easier to understand.
    I love 5 channels like i said, Rockford made a couple and stopped. In fact its hard to find a 5 channel cuz I think like all $ making ventures, you spend more when U must buy 2 amps.
    I got a RF 5 channel 600watt. 200 for the subs (100 each bridged) and 75 RMS to the infinity reference components i got. Dont let people tell you, awwww man i got a 1000 watt amp yo, who cares. Blow your speakrs, or your ears and what will you have then?
    To answer yer question, almost all full range speakrs are 4 ohm. Finding an 8ohm might be tough. Run a 4 channel capable of doing AT LEAST the minimum RMS the speakers call for, and NOT MORE. More is not good, but niether is less, but less wont blow it. If you want subs, buy another mono or 2 channel to run it and if you are gonna bridge two, MAKE SURE those are 8ohm and not 4. UNLESS of course your amp is bridgeable to 2ohm, which costs $$$$ and makes a TON of heat. Stick with 4ohm stable.
    (0.0%-) starting over
    iPad 3G 64GB, RF 600.5 amp, JL10W0V2, 8 Infinity Components
  8. #18
    Aug 2003
    The link I gave to the Hifonics is the same person I bought my Hifonics from (though mine was a higher end model). Good reputation and was quick to respond to emails.
  9. #19
    Oct 2003
    Poland, OH
    OK.. That Hifonics one you pointed out...
    ZX4400-High Power
    4 x 55 Watts @ 4 Ohms
    4 x 110W @ 2 Ohms
    2 x 220W @ 4 Ohms
    So I would only be getting 44 X 55 Watts cuz I should run it at 4 ohms?
  10. #20
    Whistle Tip pimpJ's Avatar
    Metro, TX
    That is correct, and remember that's peak wattage, not RMS
    (it's still plenty for a non-show stereo)
    Quote Originally Posted by tbird2340
    ZX4400-High Power
    4 x 110W @ 2 Ohms
    2 x 220W @ 4 Ohms
    I consider that our present sufferings are not worth comparing with the glory that will be revealed in us.
    www.neoterikos.com
  1. Speakers setup and placement
    By kingtut in forum General Hardware Discussion
    Last Post: 08-13-2007, 03:37 PM
  2. 92 range rover speakers cutting out
    By MAXXMODDER in forum Car Audio
    Last Post: 12-09-2005, 05:40 PM
  3. Replies: 12
    Last Post: 10-28-2004, 07:44 PM
  4. which speakers for my OLD bmw??? :confused:
    By thorolf15 in forum General Hardware Discussion
    Last Post: 02-04-2004, 09:22 AM
  5. MBQuart 6.5'' component speakers for sale
    By Mikesz in forum Classified Archive
    Last Post: 12-30-2002, 10:05 AM
