Page 3 of 12 FirstFirst 123456789101112 LastLast
Results 21 to 30 of 111
Thread: What's up with my BRAND NEW speakers??
  1. #21
    Whistle Tip pimpJ's Avatar
    Metro, TX
    1 word of warning that shocked me when I bought mine..
    a good new amp wiring kit will run you at least $60..
    since you're running 2 channel, maybe more
    You may be able to go used, I didn't look around at that much
    I consider that our present sufferings are not worth comparing with the glory that will be revealed in us.
    www.neoterikos.com
  2. #22
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    $60!!! What the heck is needed?? I thought just some wire and a pair of RCA's no?
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
  3. #23
    Metro, TX
    again, you may be able to find cheaper, I got a "monster wiring kit" 8 gauge for $65 new.
    there will be 2 pair of RCAs needed for you, along with a 4 gauge wire (massive). A ground wire, and a remote wire (used so the HU can tell the amp when to come on.) Also, mine came with a fuse to mount on the power wire which is a very good idea if you don't want to blow out your amp.
    www.neoterikos.com
  4. #24
    Metro, TX
    on ebay I'm finding 35-45 kits which have everything minus the RCAs (or only have one pair.) I say you need 2 under the assuption that you want stereo (left and right) sound.
    www.neoterikos.com
  5. #25
    Metro, TX
    Quote Originally Posted by pimpJ
    That is correct, and remember that's peak wattage, not RMS
    (it's still plenty for a non-show stereo)
    correction, that is 55x4 W RMS into 4 ohms. So you're plenty loud
    www.neoterikos.com
  6. #26
    Oct 2003
    Poland, OH
    So adding another 30 watts RMS is gonna make that much of a difference (being that my head unit is 25 RMS)? And 4 GAUGE WIRE!!! That is thick as heck! Why do I need two sets of RCA's? I thought one pair went from the Head Unit to the Amp?
  7. #27
    Metro, TX
    Quote Originally Posted by tbird2340
    yup yup
    quite huge..
    on the ebay link you have in this thread :
    4 Gauge Power Connectors
    I believe this because my amp (250 x 2 peak) required 8 gauge, Yours has much more power, 4 gauge seems reasonable in comparison.
    My bad, Don't know what I was thinking..
    You're right. One pair of RCAs.
    www.neoterikos.com
  8. #28
    Well you don't NEED a 4 guage wire... but most kits come with them. You will only need on set of RCAs per amp.
    I bought a wiring kit with an 4 guage wire way back when for my 200watt Extant 202. Let me tell you how happy I am now that I put the 4 guage in.... When I found this site 2 years later and decided to put a carputer in I don't have to re-run power to the trunk. I just slap a distribution block on the end on the 4 guage and can power other things.
    but again.... it's a good idea, but you don't NEED it.
  9. #29
    Metro, TX
    right, I just figure if you're going to skimp on any wire, don't let it be one that connects your battery to $100+ equipment. Overheating wires is never any fun.. Also this way, if you ever decide to put subs in and upgrade amps, I know 4 guage would be strongly reccommended for a 5 channel.
    All in all, you probably could get away with 8 gauge, but the difference is most likely about 5 - 10 bucks, I'de splurge.
    www.neoterikos.com
  10. #30
    FLAC sdashiki's Avatar
    Aug 2004
    Floreeda
    Talking
    Quote Originally Posted by Shrynn
    well you dont need 4gauge unless yer amp has the actual gauge hole in it. Most amps of a decent size/price still take 8g. Your amp is an Xtant, so yeah its gonna have 4g cuz truth be told the bigger gauge the better, always. Especially when it comes to ground, and then the POS+ battery.
    For kits, BestBuy sells RF ones, and ebay like u see is good too. But if u want hands on right now, BB or Circuit city, though both *****ty still got what you need.
    NOw you gotta think to the future too though, running more than one amp, which is why i suggest finding a 5-channel so u only need one with a 4G or even a zero gauge, will run you into problems. Especially during setup and startup kits. Cuz if u run more than one, hopefully just 2 8g and not 2 4g, youll need TWO distributor blocks. One FUSED one for POS+ and another splitter for the ground. You can always run 2 wires from the battery and 2 seperate ground wires, but thats overkill and 2x as much when it comes to kits. So if u are gonna be using more than 1 amp ever, buy the blocks now or at least know youll need them later and when it comes to buying a kit, dont skimp.
    Basic kit:
    -Battery fuse/holder, for 18" or less from positive terminal on car battery
    -usually RED power wire, 4g or 8g
    -usually BLACK ground wire
    -various end plugs for different battery posts and grounding solutions
    -either 4 channel RCAs or 2 channel RCAs
    -remote on wire, very thin usually ORANGE or BLUE for connecting to your head unit and sending the ON signal to the amp
    -and a multiple amp kit would come with the blocks, or you can buy "better" ones seperately
    make sure you buy the right kit for the right setup, 2 channel, 4 channel, multiple amp. Or buy it all seperately and maybe you might save a few bucks.
    just dont buy from Crutchfield, they are like soooooooooooo overpriced, its silly.
    (0.0%-) starting over
    iPad 3G 64GB, RF 600.5 amp, JL10W0V2, 8 Infinity Components
  1. Speakers setup and placement
    By kingtut in forum General Hardware Discussion
    Last Post: 08-13-2007, 03:37 PM
  2. 92 range rover speakers cutting out
    By MAXXMODDER in forum Car Audio
    Last Post: 12-09-2005, 05:40 PM
  3. Replies: 12
    Last Post: 10-28-2004, 07:44 PM
  4. which speakers for my OLD bmw??? :confused:
    By thorolf15 in forum General Hardware Discussion
    Last Post: 02-04-2004, 09:22 AM
  5. MBQuart 6.5'' component speakers for sale
    By Mikesz in forum Classified Archive
    Last Post: 12-30-2002, 10:05 AM
