Woahhh, Woahh, this is getting out of hand. Let me explain a few things...
Your Infinity speakers, like all coaxial factory-replacement speakers are 4 Ohm. The "100 x 2" rating you quoted earlier may be the output at 4 ohms, or 2 ohms, it depends on what the specifications say. A few of the amps I posted Ebay links to were 75watts x 2 @ 4 Ohms, meaning when the two channel amp (x 2) is connected to two 4 ohm speakers, each 4 ohm speaker "sees" 75 watts. If you increased the # of speakers to 4, and wired the pairs in parallel, (+ to +, - to - for the 2 left speakers, ditto for the right ones) the amp no longer "sees" 4 ohms. Because of the parallel wiring of adding another speaker to each channel, the amp now "sees" 2 ohms. Now that the amplifier "sees" 2 ohms per channel, it will double it's power output, going from 75 watts, to 150 watts. Each speaker will "see" a portion of this power, in this case 75 watts. I have a feeling that price is your main objective in putting this toghether. If so, buy a used 2-channel amp, and then you will only need a two-channel amp wiring kit, eliminating the extra RCA cable you would of needed for a 4-channel amp setup.
Simply, buy this amp: http://cgi.ebay.com/ws/eBayISAPI.dll...725125537&rd=1
This wiring kit: Complete 8 Gauge Amplifier Installation Kit- $18.00
http://www.knukonceptz.com/productDe...?prodID=KOLAK8
You don't need 4 gauge power wire, because you:
a- aren't running more that 500 watts, and
b- there's what, 8, 10 feet between the battery and behind the seat in a pick-up truck? 4 gauge wire would be overkill. The only way I would recommend it, is if you planned on adding another amp for a subwoofer later.
Then get some blue crimp connectors from Radio Shack, or Home depot, or similar store: $5.00
Run the speaker wire that comes in the kit from the output of the amp to the dash, behind the radio. Connect the other ends with the blue connectors to the wires that go to the speakers. Tape off the speaker wires coming out of the deck. Run the RCA cable that comes in the amp wiring kit from the amp's RCA inputs to the front RCA outputs of the deck. Run the 8 gauge blue power wire from the battery to the supplied fuse holder (within 18"), then to the power input on the amp. Run the ground wire from the amp to the silver 8 gauge wire, then to a nearby clean, solid metal ground, like a seatbelt bolt. Mount the amp to a wood plate, not to the metal of the truck, this will create noise if it is done. Connect the remote output of the deck to the middle wire in the RCA's, then to the remote input on the deck. Set the gain(s) control on the amplifier to full minimum (counterclockwise). Play some familiar music in the CD deck at it's full undistorted output, then slowly increase the gain on the amp until you hear distortion. Back the gain down slightly, and you're done! Estimating that the amp above goes for $75, you've spent a total of $98 plus shipping and tax, and your system is a heck of alot cleaner, louder, and distortion-free.![]()
LinkBack URL
About LinkBacks
The "standard" impedance (think resistance) of home speakers is 8 Ohms, and for mobile audio, it is generally 4 Ohms. Therefore, car audio manufacturers spec and build their amplifiers to put out a set amount of
