Ok.. Still planning on buying an amp but I'm still a little confused about the whole 2 ohm / 4 ohm.. I understand that if I get a 2 channel amp that is rated at say 50 W X 2 @ 4 ohms and I hook all four of my speakers up to this amp that it then changes the rating of the amp to 100 W X 2 @ 2ohms and it also makes the amp get a lot hotter. This is the conversation I had with a crutchfield rep about whether or not I should run them at 2ohm or 4ohm:
A Product Advisor will be with you in a moment. Please be sure to include their name as you checkout.
{Stephen} If you're driving full-range components or two-way or three-way speakers (anything but subwoofers), I don't recommend you work @2ohms. It's not as clean and you can hear the difference in regular speakers (you can't detect it with subwoofers because the frequency range is too low to hear the difference).
{Tom} So I should look for an amp that runs four channels at 4 ohms?
{Stephen} Yes, exactly. The Infinity Reference amplifier I gave you the link for is perfect.
{Tom} OK thanks for your time.
{Stephen} If your budget is too tight for that, don't go with a 2 channel amplifier, though.
{Stephen} On the low-end, I might suggest this Profile amplifier with 80 watts per channel --
Profile AP1040
80W x 4 car amplifier
http://www.crutchfield.com/cgi-bin/P...sp?i=489AP1040
So it sounds like he's saying that there is a big difference and that it may even be bad to do that?
LinkBack URL
About LinkBacks
