Page 6 of 12 FirstFirst 123456789101112 LastLast
Results 51 to 60 of 111
Thread: What's up with my BRAND NEW speakers??
  1. #51
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    So if I won an amp at the specs above would you recommend I run it at 50 W X 4 @ 4ohms or 100 W X 4 @ 2ohms?
    I know just because the amp pushes that much that I don't necessarily have to use that much but the speakers are 100 W RMS so I just thought that would be the best way to go.
    And what do you think of these amps here (trying to stay around $75):
    ROCKFORD FOSGATE 300X 4 CHANNEL MOSFET AMP
    Rockford Fosgate Punch 400A4
    ROCKFORD FOSGATE 550X
    Rockford Fosgate Punch 400.4
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
  2. #52
    Maximum Bitrate Snootch's Avatar
    Sep 2003
    Tampa, Florida
    The 400a4. See if you can email the seller for a clearer picture of the birthsheet. It will tell you the actual power output of the amp when it was bench tested at the factory.I bet you it'll do over 50 watts per channel at 4 ohms.
    EDIT: looking at the bold text on birthsheet, It says 544 watts rms total power into 2 ohms, all channels driven. If so, then half of that, then divide by four gets you 68 watts rms per channel. Oh,BTW, are those infinitys rated for 100 watts MAX each, or 100 watts RMS each?
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
  3. #53
    Oct 2003
    Poland, OH
    100 Watts RMS each.
    What should I expect that amp to go for?
  4. #54
    Sep 2003
    Tampa, Florida
    I would assume somewhere in the $50-$75 range. I noticed they are asking $25.00 for shipping as well.
    WORKLOG
    Webpage
  5. #55
    Jun 2004
    Bay Area, California
    Quote Originally Posted by tbird2340
    Answer to your quiz:
    I would say you done screwed yourself
    bingo. poor equipment matching, im glad you got it right on the nose. couldnt have said it better myself.
    So.. Another example would be that if I used a 2 channel amp rated 100 X 2 @ 4 ohms and only hooked two speakers up to it my speakers would get 100 Watts a piece at 4 ohms. However, if I decided to run all four speakers off this 2 channel amp in parralel then it would change the rating to 200 x 2 @ 2 ohms which means all FOUR of the speakers would be getting 100 W's a piece but I guess it would drop them down to 2ohms? Which.. Why would that be bad?
    Ill just repeat what was already said, since the only reason its bad was already said, you lose front/rear fade. So if you dont care about front rear fade, there IS no reason why it would be bad! But if you do, then a 4 channel amp is the only way to go. or two two channel amps.
  6. #56
    Oct 2003
    Poland, OH
    I am STILL trying to get an amp on my budget. A guy from a forum said he'd sell me a
    "Power Acoustik LT960/4 that I've used for 2 months. Bought from authorized dealer so it should still have warranty.
    100 x 4 @ 4 ohms
    125 x 4 @ 2 ohms
    250 x 2 @ 4 ohms
    lots of features, great condition, running a set of pg titanium elite components off it in bridged mode. Probably one of the few budget lines that puts out what it says.
    $90 shipped.....its pretty big"
    What do yall think?
  7. #57
    Jun 2004
    thats 100 rms or 100 peak?
  8. #58
    Oct 2003
    Poland, OH
    Or how about this one Power Acoustik LT-720/4 for $77 shipped.
    The specs on the two amps are as follows:
    Power Acoustik LT-720/4 - $77
    Performance
    Frequency Response 10 Hz - 30000 Hz
    High - Pass Frequency 50 Hz - 500 Hz
    Low - Pass Frequency 30 Hz - 500 Hz
    Signal to Noise Ratio 98 dB
    THD at Rated RMS Power 0.02 %
    Power Output
    RMS Power at 2 Ohms 100 W x 4
    RMS Power at 4 Ohms 85 W x 4
    Power Acoustik LT-960/4 - $90
    Performance
    Bass Boost Frequency 40 Hz
    High - Pass Frequency 150 Hz - 1500 Hz
    Low - Pass Frequency 40 Hz - 120 Hz
    Signal to Noise Ratio 97 dB
    Power Output
    RMS Power at 2 Ohms 125 W x 4
    RMS Power at 4 Ohms 100 W x 4
    I'm guessing Power Acoustik isn't exactly the best since these amps brand new aren't over $150... However, I don't need something all that great.. Just enough to get me past my clipping problem.
  9. #59
    Oct 2003
    Poland, OH
    GRIPES!!! My head unit only was one set of pre amp outputs... So if I get a 4 channel amp I will have to run them it at 2 ohms huh (the left speakers tied together and the rights tied together)..
    If this is the case.. Is it impossible to add a sub down the road with having only one set of RCA outputs?
  10. #60
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    its not hard to split the pre outs into as many channels as you want, i have 2 channels split into 4 channels to go into an amp in my car
    Signature: [==||========] 20% complete
  1. Speakers setup and placement
    By kingtut in forum General Hardware Discussion
    Last Post: 08-13-2007, 03:37 PM
  2. 92 range rover speakers cutting out
    By MAXXMODDER in forum Car Audio
    Last Post: 12-09-2005, 05:40 PM
  3. Replies: 12
    Last Post: 10-28-2004, 07:44 PM
  4. which speakers for my OLD bmw??? :confused:
    By thorolf15 in forum General Hardware Discussion
    Last Post: 02-04-2004, 09:22 AM
  5. MBQuart 6.5'' component speakers for sale
    By Mikesz in forum Classified Archive
    Last Post: 12-30-2002, 10:05 AM
