Page 7 of 12 FirstFirst 123456789101112 LastLast
Results 61 to 70 of 111
Thread: What's up with my BRAND NEW speakers??
  1. #61
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    Phew.. Now I just need the advice on my amp..
    Thanks Nic
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
  2. #62
    Falls Church, VA
    Ohh man, I actually read through this whole thing. A lot of misconceptions and a lot of good advice...
    Now for a lil background to help my advice.... I started working for the largest car audio shop in western New York at 17 as a sales guy. In the 10 years following, I have gone from sales, to installations, to owning my own shop, to dumping car audio all together Regardless, I have picked up quite a bit of knowledge in the process.
    So lets break this down and keep things as simple as possible. I am going to explain things in simple terms, if others want to argue my points, feel free to send me a note and I would love to get technical, but just don't take over this thread.
    1) The noise you hear is from overdriving the outputs of the head-unit, more or less making it push too much power to equal the volume you would like. What people have mentioned about clipping is dead on. We need to find out a way to get you the volume you want without clipping.
    2) The speaker mounting charecteristics (sp?) of Ford trucks are rather lousy. One of the things you will want to do is ensure the front side of the speaker is sealed from the back side. They sell lil foam baffles that work rather well for what you are trying to do. You basically pull out the speakers, slide the cups over the back and mount them back in. A cheaper experiment you can try is simple duct tape. Remove the speaker covers and look for holes in the sheet metal that would allow air from the back of the speaker to come to the front. Then apply a couple layers of duct tape to it. It may help, i repeat, MAY. I usually do this on door speaker installations.
    3) Yes, oval speakers have standing wave issues, all speakers do. Doing what I described in #2 will help. With a decent amplifier, you will never get to the degree where you will notice the difference between the standing wave characteristics of one speaker to another. The speakers you bought are excellent, don’t let anyone tell you otherwise.
    4) Amplifiers and ohms… Let me make this a simple decision for you… Buy a decent named 4 channel amplifier. When I say decent, try to stay with brands you have heard of before. I personally like Phoenix Gold amplifiers from the mid 90’s. There are some great deals on these on ebay. Rockford Fosgate, a/d/s, PPi, Soundstream, Earthquake, even Pioneer and kenwood are all sufficient for what you are trying to do. Stay away from no name brands and weird brands that are a mix of two names you have heard of before. The major problem you will notice is ground noise on these weird amps, which is quite annoying, especially for someone just starting out.
    Now if you buy a 50 watt per channel amp, it is NOT half as loud as a 100 watt amp. In fact, to double the volume of a 50 watt amplifier, you will actually have to give it about 10 times the power, or add several sets of speakers. Regardless, my point is a 50 watt amp will be plenty. Find an inexpensive 50 watt X 4 amp.
    Why a 4 channel compared to a 2? Well its all about control. Chances are the rear speakers are very close to sensitivity (how efficient they are) compared to the fronts. But they are not exactly the same. What does this mean? Well if you run the fronts and rears off of one channel, one may be louder and there is nothing you can do about it. This would annoy the HELL out of me. I want to be able to turn the back down to a point where its maybe a lil stronger in the fronts than the rears. I like the control of a fader, its there for a reason. I realize you only have one set of RCAs out, but that’s ok, you can buy lil Y adapters for the RCAs so it feeds all 4 channels. Then you can use the gains (adjustments) on the amplifiers to work out volume in the front to the rear.
    Don’t bother looking at 2 ohm ratings right now… Like I said above, more power is not needed. Just pay attention to the 4 ohm rating.
    5)Wiring…. As they advised in an earlier post, just use a cheap 8 gauge kit. Make sure you fuse the power wire with the included fuse. Next make sure you ground the amplifier to a CLEAN ground. This means making your own screw point by finding a strong piece of metal, cleaning off the paint to make a shiny metal surface about the size of a quarter, and using a self tapping screw to attach the ground. Toss a lil grease on top of it to prevent corrosion.
    Next, as described, its probably easiest just to run all 4 pair of speaker wires behind the head-unit and tap into the factory wiring. It will take some thinking to make sure you have all of them hooked up to the proper location (I use a 9 volt battery as a way to “pop” the speaker so I know which wire goes where). But once you figure it out you are good to go.
    I know this is a lot, so if you have any questions let us know and we will try to help.
  3. #63
    Oct 2003
    Poland, OH
    WOW... Thanks for that informative post Will.. Some of the things I got out of it..
    Basically stay away from the two amps I posted links too right ?
    Also, Your #2 point may have something to do with my problem... I originally had 5x7's in my rears (stock) and I had to sorta jerry rig to get my 6X9's to fit. I had to drill new holes to get them in.. Your saying to make SURE the speaker is FLUSH with the door? That no air can get through??
    Thanks for the amp advice. So now I'm basically looking for a 4 channel amp that is running 50 X 4 RMS at 4 OHMS.
  4. #64
    Falls Church, VA
    Quote Originally Posted by tbird2340
    Well yeah pretty much. You see you can get away with cheaper amps, but you want to have an investment, not a headache. Used amplifiers are so cheap that I really recommend getting a good named brand. I spent years on the repair end of home and car electronics and its the inside that counts. Most of the amps I have mentioned all have decent components and that is VERY important. It just means a stronger, better sounding amp (yes yes audiophiles, i know the Autolab 2000 challenge) can often be a better value than a huge power, weak internal amp. There is a reason they are a lil pricey... its because they are better.
    Exactly! Yeah, lets get that speaker mounted correctly. It mush be flush. If that means getting some tin snips out and cutting a lil metal, then do it. It needs a strong seal, a strong baffle to prevent the sound waves eminating from the back to cancel out those in the front. Since sound travels via vibration of air molecules, we have to seperate the air in the back, from the air in the front. Make sense?
    And yeah, buy a nice lil 50 watt X4 amp. Make it a decent one and plan on holding onto it for a decade or so. This lil guy will be with you for a long time!
  5. #65
    FLAC sdashiki's Avatar
    Aug 2004
    Floreeda
    alot on amps and speakers, IMO, have to do with where you live.
    Does it get REALLY cold ever?
    Like, does it snow and/or 20F degree or less for a few months out of the year? AWESOME yer carputer probably runs alot faster, but yer speakers probably sound like **** at first until the car heats up. For this I suggest Boston Acoustics, built for new england weather, so heat or cold the speakrs wont warp, break, distort or run any less than normal.
    Now for HOT, like Arizona and Florida most of the SW-SE, but I mean really hot. Some places get hot but the radiation doesnt heat the inside of the car up as much as Phoenix. Anyway, I suggest Rockford Fosgate amps for HOT places because RF is from Arizona, the middle of the desert, and their amps are specifically made to run HOT and run as efficient as cold. IE getting into your car when its an oven and turning on yer system shouldnt be a problem.
    NOw I truly dont know if HOT/COLD is really a huge factor for most people, but HOT especially for carputers, is a hurdle.
    (0.0%-) starting over
    iPad 3G 64GB, RF 600.5 amp, JL10W0V2, 8 Infinity Components
  6. #66
    Oct 2003
    Poland, OH
    Yet another stupid question. If I get a 4 channel amp and run it correctly with one speaker going to each channel... It wouldn't be possible to add a sub to this amp or would it??
  7. #67
    Whistle Tip pimpJ's Avatar
    Metro, TX
    not really, you could run another amp along with this one, but to answer your question.. not realistically. If it were possible, it wouldn't be pragramtic. Also your HU probably has a sub output. You'de want to run your subs through these.
    I consider that our present sufferings are not worth comparing with the glory that will be revealed in us.
    www.neoterikos.com
  8. #68
    Metro, TX
    but, on the bright side, a 1 or 2 channel amp is not very expensive. You can find a decent one for <$50.
    www.neoterikos.com
  9. #69
    Jun 2004
    Bay Area, California
    did you ever get around to checking those infinities for standing waves?
  10. #70
    Falls Church, VA
    Quote Originally Posted by WhiteRabbit
    Are you sure you are using the proper term here? A speaker by itself cannot produce a standing wave based upon cone flex. A standing wave is produced by the interaction of two wave lengths moving towards each other. This is normally caused by the reflection of a previous wave back to the origin (speaker). That said, the standing wave is dependent upon the physical properties of its environment, and not the speaker itself.
    Secondly, you can not "see" a standing wave by looking at a speaker. You may be able to see the movement of the speaker, but not hear the proper volume. If thats the case, you have cancellation somewhere, or extremely low frequencies. but once again, it is not the speaker but the properties of the environment. Possible reflections or improper baffleing causes this all the time.
    I can understand noticing a distortion at low frequencies with the Infinity speakers. They are simply not designed to produce low volumes in a free-air environment. Using a crossover helps this. But I will guarantee that the speaker does not move anyway but linearly. Yes, maybe the cone flex is visible, but you would have to have a hell of an eye.
    Non-circular speakers do suffer from cone flex issues. Cone flex changes the harmonics of a speaker slightly, causing it to "ring" at a frequency other than that in which it is trying to reproduce, especially at high volume levels. This problem is so minimal that only the highest of audiophiles get a bug up their butt about it.
    I prefer a round speaker for different reasons. I stopped selling 4x3/5x7/6x8/6x9s a long time ago. Instead, I would sell a normal round speaker and an adapter plate. For the money, people could purchase a higher quality 6.5" and place it in the 6x9 slot. It always amazed me how much companies like pioneer would charge for the oval speakers compared to their relative quality.
    Anyways, i really can not agree that these speakers, or any speaker alone, can have inherent standing wave issues. Remember, its the enclosure/environment....
  1. Speakers setup and placement
    By kingtut in forum General Hardware Discussion
    Last Post: 08-13-2007, 03:37 PM
  2. 92 range rover speakers cutting out
    By MAXXMODDER in forum Car Audio
    Last Post: 12-09-2005, 05:40 PM
  3. Replies: 12
    Last Post: 10-28-2004, 07:44 PM
  4. which speakers for my OLD bmw??? :confused:
    By thorolf15 in forum General Hardware Discussion
    Last Post: 02-04-2004, 09:22 AM
  5. MBQuart 6.5'' component speakers for sale
    By Mikesz in forum Classified Archive
    Last Post: 12-30-2002, 10:05 AM
