Page 1 of 12 1234567891011 ... LastLast
Results 1 to 10 of 111
Thread: What's up with my BRAND NEW speakers??
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    OK.. I replaced my rear speakers in my truck with Infinity Kappa 693.5i 6x9" 3 way speakers. They sounded great with my stock head unit and even better when I got my new head unit (25 X 4 RMS). When I turned it up to a certain volume it sounded like they were blown.. I don't turn the bass up and they weren't even hitting hard. I ended up sending them back and getting another brand new pair. I then got a set of Infinity Kappa 572.5CF 5x7" 6x8" 2 way speakers to replace my stock fronts.. I'm not experiencing this "sound" with all 4 speakers. I know there is no way they are blown because Infinity makes high quality stuff and I don't think my luck is that bad. They sound fine at low to mid volume but when I really want to jam I start to hear the sound (like popping hissing... hard to explain).
    Anyone have any ideas of what can be wrong?
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
    Constant Bitrate nirvanades's Avatar
    are the speakers hooked up to your head unit? or an amp? You said you got a new pair - are they working fine? and now the fronts are the problem?
    2003 Chevy Tahoe Z71
    STOLEN - M10000, 512MB, 60GB 2.5" HDD, 7" Custom mounted Lilliput, Morex 3688 Case, 90W PSU w/ ITPS, GPS & CD-RW/DVD. New parts ordered for the next generation!
    FLAC sdashiki's Avatar
    Aug 2004
    Floreeda
    I bet u got LOUDNESS turned on.
    Whether you do or not its worth knowing, if u dont got an AMP, yeah loud can make it sound a little more rich, but at the expense of all it doing is upping the gain on the waveform that goes thru the HU. SO it can clip without u knowing it really, and in time sounds like crap during certain freqs. My advice to anyone WITH LOUDNESS as a button or feature, DONT EVER TURN IT ON. Tweak yer damn EQ to make it sound that way. Loud is BS and is really only good for stock only, cuz they are made of paper 99% of the time anyway.
    dont take a chance with 3rd party $$$ speeakrs.
    (0.0%-) starting over
    iPad 3G 64GB, RF 600.5 amp, JL10W0V2, 8 Infinity Components
    Maximum Bitrate brrman's Avatar
    Aug 2003
    Indianapolis, IN USA
    It's what is known as "clipping".
    Your headunit is not pushing enough juice to sustain the high output you are demanding. You need an amp. These speakers are RMS 100W each - and you are trying to support them with 25W/channel. You run out of juice, man.
    Basically the top of the sine wave is being clipped off so instead of a nice curved sound wave, you get one that begins the upcurve, but then goes flat, and then begins its downcurve.
    Constant use hearing this will ruin your speakers, keep the volume down until you can get an amp that will push enough power to support the high volume.
    Car: 2000 Audi A4 Avant 1.8t
    Carputer 2.0: removed. Back to stock.
    Oct 2003
    Poland, OH
    This forum is da bomb... Thanks for clearing it up.. That sucks that I have yet another expense now though.. I do have the "LOUD" feature turned on and it does seem to make them sound better but I will turn it off like you suggest. It happens with both LOUD on and OFF.. Just at high volumes! I do not have an amp yet. What is a good amp (reasonably priced) for powering these?
    Thanks again!!
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Tidder
    Try RevFE
    Oct 2003
    Poland, OH
    Ouch $199... Me no have that much loot...
    So am I looking for something that is X Watts x 4?
    And I haven't had a system for about 6 years... Do the speaker wires go directly to the amp or do the RCA's go from the amp to the head unit?
    For reference:
    Infinity Kappa 572.5cf
    Recommended power range 2-100 watts RMS
    Peak power handling 300 watts
    Recommended power range 2-110 watts RMS
    Peak power handling 330 watts
    Sep 2003
    New Mexico, USA
    I would say for something to sound decent, you need to find an amp that puts out between 110 to 200 watts per channel. It's a common misperception that you need to match outputs to speaker wattages. You want to go a little higher to get a good crisp sound.
    That's my $0.02 anyway.
    Tidder
    Try RevFE
    Aug 2004
    St. Louis, Missouri (USA)
    if one of the speakers are out phase it can cancel out lots of sound and make them sound like crap.
    make sure all the positives and negatives are correct on the hu/amp and speakers.
    Maximum Bitrate Naamanf's Avatar
    Sep 2003
    Colorado
    [QUOTE=Tidder]I would say for something to sound decent, you need to find an amp that puts out between 110 to 200 watts per channel. It's a common misperception that you need to match outputs to speaker wattages. You want to go a little higher to get a good crisp sound.
    That's my $0.02 anyway.[/QUOTE
    You really don't need that much power. A good amp that puts out a true 50-75 watts would work just fine. Just don't try to get any deep base from them. They are not a sub so don't expect them to sound like one.
    2007 Tahoe
    Opus with iBase 896 and Pentium M 735 Transflective Xenarc Alpine DVA-9861, PXA-H900, Sinfoni 45X2 (2) 90x2, Genesis Dual Mono, JL 1000/1 (2), Focal Be tweeters, ScanSpeak Revelator Mids, Dynaudio MW170, Dayton 12" Ref.
    My Install
  1. Speakers setup and placement
    By kingtut in forum General Hardware Discussion
    Last Post: 08-13-2007, 03:37 PM
  2. 92 range rover speakers cutting out
    By MAXXMODDER in forum Car Audio
    Last Post: 12-09-2005, 05:40 PM
  3. Replies: 12
    Last Post: 10-28-2004, 07:44 PM
  4. which speakers for my OLD bmw??? :confused:
    By thorolf15 in forum General Hardware Discussion
    Last Post: 02-04-2004, 09:22 AM
  5. MBQuart 6.5'' component speakers for sale
    By Mikesz in forum Classified Archive
    Last Post: 12-30-2002, 10:05 AM
