Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: what does this tell me? (regarding whine in speakers)
  1. #11
    Maximum Bitrate falconey's Avatar
    Feb 2004
    Atlanta
    Quote Originally Posted by heypachuco
    This is a big no-no.
    Keep you signal and speaker wires away from power wires. Noise can get in that way too.
    And double check your ground points. Are they a clean connection to bare metal, or are they connected to a bolt through a painted panel? A good ground will resolve many problems before they come up.
    He's right you shouldn't run speaker and power wires together. This isn't your problem though. The key here is you stated it only happens in AUX. Ground your pc case and let us know what happens. Matter of fact you can do an easy test. Take some wire and strip the ends. Touch one end to the metal on the case and the other to some part of the car chasis. See if the whine goes away. If it does do a more permanent install of the case ground.
  2. #12
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    I checked everything numerous times and ending up getting a ground loop isolator from Wal-Mart for $12 and it fixed it.
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
  3. #13
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    The "Speaker whining" usually happen when power wire (from battery to devices) and signal wire (audio RCAs and Speakers) are running parallel with each other.
    Try to run power wire on one side of the car and signal on the other side or middle of the car. Only cross the 2 when there is no options.
    Do the speakers still whining when you are just listening to radio?
    Ground loop isolators somewhat help but it just a "bandage" solution.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  4. #14
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    Here's my .02 cents. Buy a ground loop isolator from radio shack. (10.00)
    haha, the poor radio shack guy's gunna **** his pants when you ask him for it too (cause you know how they always act like they know everything)
    He's gunna think your some kind of weird scientist... muahahaha
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
  5. #15
    Nov 2003
    Olympia, WA
    One word about ground loop isolators...you may lose some sound. I did with mine. I grounded my headunit and that fixed it. I had the same exact problem as described. When my hu was switched to aux then I had noise even with the computer off and when it was disconnected. I attached an extra wire to the metal holder (I don't know what it's called) of my hu and grounded it. It took care of the noise.
  6. #16
    Feb 2004
    Smile
    Yesterday I picked up a Ground Loop Isolator from Radio Shack for $17. This stopped the whining sound completedly. I was shocked!! Thanks!!
  1. Speakers setup and placement
    By kingtut in forum General Hardware Discussion
    Last Post: 08-13-2007, 03:37 PM
  2. 92 range rover speakers cutting out
    By MAXXMODDER in forum Car Audio
    Last Post: 12-09-2005, 05:40 PM
  3. Replies: 12
    Last Post: 10-28-2004, 07:44 PM
  4. which speakers for my OLD bmw??? :confused:
    By thorolf15 in forum General Hardware Discussion
    Last Post: 02-04-2004, 09:22 AM
  5. MBQuart 6.5'' component speakers for sale
    By Mikesz in forum Classified Archive
    Last Post: 12-30-2002, 10:05 AM
