Using an inverter? Does it make noise with the inverter turned off?
When i have my headunit set to AUX input and my computer is totally off...no power plugged into it, i can still hear the engine whine thru my speakers.
Of course, if i unhook the sound wire from the computer, the whine is gone.
But im wondering what you guys can deduece from this...if anything.
What direction should I head in?
If this wine occurs only when the car is running AND it fluctuates w/ throttle position.. then you'll need to check your wiring for grounds. --or add some emi filtering
•Micke
Usually ground is the problem.
Can by ur dynamo. I have a stupid dynamo (all rusty), and i switched it with a new 1 from the junkyard and now its working better. Check your battery connectors for rust, you will always have a bit of this beacuse of the large power going trough the cables to your pc (and amps?) and your audiocables who are scrambled a bit by this power (magnetic field of the cable).
051°55'30"N 04°34'31"E
im using an opus. but i have the opus totally unhooked from the computer at this time..
And yes, the noise does fluctuate with throttle position.
I dont understand how a ground can be a problem. What am i supposed to ground? Cause this noise is happening with NO power and the only thing hooked into my computer is my sound wire.
I do have the speaker wire running next to my 8awg power wire. let me try unhooking the power wire from the battery and see what happens
There is no noise when your engine isnt running and what is the only thing that flucates when u trottle? Your dynamoIt can be that the ground of your radio came loose, if you have more then 1 ground point it can make this noise too (ground loops)
NappyJim, I'm beginning to think you haven't done any research at all. If you don't know anything about car stereo installation, or computers, research a bit. You'll be amazed at what you find. Best thing though, don't think you know what you're doing. Sometimes you'll find the answer is far from what you thought was going to fix the problem.Originally Posted by nappyjim
I am having the same problem. I have no clue what to ground! The head Unit is already grounded, so what else is there? I think I have seen some RCA wires that have an extra extention for ground. Is this what I need to get rid of the Whine? It is not a loud whine, but I do notice that it is there only when the car is on and fluctuates with acceleration.
This is a big no-no.Originally Posted by nappyjim
Keep you signal and speaker wires away from power wires. Noise can get in that way too.
And double check your ground points. Are they a clean connection to bare metal, or are they connected to a bolt through a painted panel? A good ground will resolve many problems before they come up.
