Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Amp wont turn on, just keeps blinking, help!
    Maximum Bitrate pyros's Avatar
    Mar 2004
    Toronto, Canada
    Hey everyone,
    I bought a used Clarion APX400.4 amplifier off a friend. I wired it up and when I try to power it up (turn on the stereo), the power LED just keeps blinking once every maybe 5 seconds and I hear a slight pop in the speakers. I tested the connections with a multimeter and they all appear fine. Any ideas what might be wrong and/or how I can fix it?
    Thanks,
    Chris
    2004 Ford Mustang Mach 1
    Specs: Epia M2-1000, 512mb ram, SB Audigy NX, Lilliput 7" Touchscreen, M2-ATX, DVD, 160gb HDD, gps, obdII, wifi, bluetooth, XM radio, HQCT and Logitech wireless gamepad.
    Install Status: DONE
    My XM FAQ
    Low Bitrate megamind's Avatar
    Aug 2004
    Netherlands, Rotterdam
    Is your ground ok? This is the most common problem...
    051°55'30"N 04°34'31"E
    Jul 2004
    Ohio
    Check your ground, fuses, and wires/connections. What size amp and what gauge wiring are you using?
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Like he said... check all your connections. then double check, mine has done that a couple times and it was always mis wiring
    Newbie Ninety8NeonACR's Avatar
    Feb 2002
    WI
    my guess is check the ohm load.
    Chris
    Car=Dodge Neon ACR.
    PC=Cappuccino GX1 Mini-Book - 800MHz, 256MB ,5GB, CD, XP payed $230
    Screen=8" Lilliput XGA T/S payed $360
    ITPS payed $46
    DVD Drive payed $43
    Ebay GPS Mouse + Software payed $52
    Variable Bitrate BiohazrD's Avatar
    Katy TX
    My first guess would be the remote wire. Make sure that it has a good connection. I went through hell with one of my amps because of a single remote wire.
    Quick! To the Popemobile!
    Mar 2004
    Toronto, Canada
    i've checked all the connections, they are fine. i thought it was the ohm load too, doesn't seem to be. if i disconnect all the speaker wire and try to power it on, i get the same thing. the fuse keeps popping, so i just jimmy rigged a bypass and it still doesn't power on. just keeps blinking. god damnit. i think its fried
    My XM FAQ
    Aug 2004
    If you bypass the fuse then that chance is big yea
    Mar 2004
    Toronto, Canada
    i bypassed it after everything else failed
    My XM FAQ
    Maximum Bitrate falconey's Avatar
    Feb 2004
    Atlanta
    Which fuse is popping? The amp fuse?
  1. PC Motherboard to 1 amp or 2?
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  2. Can Opus 90W remote turn on AMP and LCD >
    By Gibbon in forum Power Supplies
    Last Post: 10-16-2004, 09:57 AM
  3. Opus remote trigger. Amp turn on
    By live2themaxuk in forum General Hardware Discussion
    Last Post: 09-08-2004, 04:37 PM
  4. Need some help with sending audio to stock amp
    By orangewhip in forum General Hardware Discussion
    Last Post: 09-04-2003, 02:21 PM
  5. amp turn on
    By jasmar in forum General Hardware Discussion
    Last Post: 07-21-2000, 09:51 AM
