Results 1 to 10 of 13
Thread: no name FM modulator....
    Oct 2004
    I bought a no name FM modulator and i can barely hear anything/ ****ty. Is it because it's a no name? Thanks!
    Maximum Bitrate EBFoxbat's Avatar
    Jun 2004
    Massachusetts
    no, it's because it sucks
    ,./(0)3
    '04 Canyon 4x4 pickup
    [---PC on hold----working on external fiberglass "tool" box---]
    Variable Bitrate blurp's Avatar
    Sep 2003
    Hampshire, TN
    Quote Originally Posted by EBFoxbat
    But seriously, are you sure it is a modulator or is it a transmitter? Have you checked all of the obligatory things like replacing the cable, sound settings on PC, etc?
    www.bradleyjacobs.com
    There is more stupidity than hydrogen in the universe, and it has a longer shelf life. -- Frank Zappa
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Got what you paid for, return if you can. Learn from that mistake.
    TruckinMP3
    Read the FAQ!
    Variable Bitrate HummDinger's Avatar
    Aug 2004
    Milwaukee, WI
    Wink
    I bought this FM transmitter and have it hooked up to a 12 volt supply from the molex connector. It works great. No noise, no static, crisp and clear. Also wireless... and only $35.00
    ebay link
    I have tried the USB line-X and got a lot of line noise as well as static. Plus only 6 channel selections, no good hear. I have also tried an inline modulator, very bad choice. Lots of line noise, alternatore noise and poor sound quality. Ditch the modulator and get a transmitter like the one above, it works great.
    You can still have something if you have nothing
    Oct 2004
    The one I have right now is this: http://cgi.ebay.com/ws/eBayISAPI.dll...718518506&rd=1
    I think I will look into the FM transmitter... thanks everyone!
    Aug 2004
    Milwaukee, WI
    Quote Originally Posted by krazE
    That is the same one I was using, pretty funny actually I battled with the sound issues for about 1 year, then I gave up and tried something different and low and behold it works.
    Sep 2003
    Hampshire, TN
    You'll probably regret that. I used one at first, and it sounded great for about a month, then turned to crap. Most others on this forum who have used them expressed the same sentiment. I now use an audiovox modulator, and it's been sounding great for a year. Just be sure to ground everything PROPERLY. for what I mean on that.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    I just digging thru my factory HU yesterday and found a way in integrate "Aux input" that I think can sound much better than any "adapter" except the true aux input adapter. That is to tap into the Analogue audio signal from the CD part to amplifier. I will post the complete procedure when I get home.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Sep 2003
    Beach City, Socal
    Ok here is what I did on a GM/AC/Delco made Radio on my Toyota Matrix (this radio is similar to most radio on GM cars/trucks)
    - Trace the audio signal from the CD player to the amplifier board by using head phone. Cut the plug to expose bare wire or solder/tape 2 piece of wire (GROUND and LEFT or RIGHT) to the plug and use it to probe around.
    I found 2 signal wire on a 6 pins connector (Black pin 1 is LEFT and white pin 3 is RIGHt pin 2 is GROUND).
    I cut that 2 audio wires pin 1 and 3.
    Solder a DPDT relay
    The result is a mini stereo jack for aux in and a wire dangling out side to enable and disable aux input (driven the relay)
    There is NO noise or engine whine when I use a discman to feed the audio. No computer setup in the Matrix yet so I don't know if there will be noise with the PC.
  1. FM Transmitter vs. FM Modulator
    By Uzi4U in forum Newbie
    Last Post: 02-18-2005, 10:20 PM
  2. Integrate mp3 player w/ Alpine FM modulator ?
    By L0C0 in forum General Hardware Discussion
    Last Post: 03-04-2004, 01:45 AM
  3. FM Transmitter / FM Modulator
    By owenjh in forum General Hardware Discussion
    Last Post: 12-30-2003, 07:29 PM
  4. FM Modulator... which one?
    By justinham in forum General Hardware Discussion
    Last Post: 04-02-2002, 12:56 PM
  5. Which one is better? FM Transmiter or FM Modulator
    By helloman in forum General Hardware Discussion
    Last Post: 03-12-2001, 10:15 AM
