Results 11 to 20 of 28
Thread: Red Red Whine....
  1. #11
    Bowel movement jjh221's Avatar
    Dec 2003
    not sure yet.
    I had the same problem . I had my lilliput powered by my psu, and i found when i turned off the lilliput most of the idle noise went away, but still having the harddrive and engine reve noise. So what i did next was solder the lillput to the cig lighter. Work, well for that much. I still had the harddrive noise and engine rev noise. So what i did next was ground the mobo to the same ground, on the cig lighter, as the lilliput. My problem was solved.
  2. #12
    Ok,
    I'm going to ground everything to one point, and see what that fixes.
    Though I'm not clear on how to ground a motherboard.
    Can anyone help with this ?
    Cheers,
    Matt
  3. #13
    Maximum Bitrate EBFoxbat's Avatar
    Jun 2004
    Massachusetts
    The ATX power (from the OPUS) should take care of your motherboard ground.
    ,./(0)3
    '04 Canyon 4x4 pickup
    [---PC on hold----working on external fiberglass "tool" box---]
  4. #14
    I'm still a little unclear about grounding audio.
    I have a headphone jack line out that goes into RCA left and right.
    Am i cutting into each of these wires and making a ground, or am I using the shield wire aroud them and grounding that ??
    Cheers,
    Matt
  5. #15
    Dec 2003
    not sure yet.
    My mobo is not in a case, but screwed to some plexy glass. Your ground on the mobo is where the screws go to hold it to what ever it is attached to. If ya notice the holes are circled in metal or whatever.
    If your audio is to your head unit i would think that that is already grouned.
  6. #16
    Quote Originally Posted by jjh221
    Ok, so if the mobo is screwed into the metal case and the audio is going to the headunit then by default they are all grounded. Therefore, if I ground the case again, (just to be sure), ground the Xenarc, and the opus all to a good grounding point below my spare wheel together, then all my problems, in theory, will disappear.
    Is there anything else I need to do, test or check ??
    Thanks,
    Matt
  7. #17
    Ttt
  8. #18
    Ok,
    I have tried grounding everything to the same point on the chassis below the spare wheel. This included the Opus, Opus chassis, PC case, and Xenarc.
    This solved very little.
    Does anyone have any other ideas........
    A reminder of the symptoms and tests:
    Engine related noise, hardrive related noise. Only when PC is switched on.
    See first post for full description.
    What else could I do. What about a sound card ? Might that help ?
    Many thanks,
    Matthew
  9. #19
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    An external soundcard could help, as onboard soundcards are badly shielded from other PC-components.
    Do some more tests, replacing or disabling individual components such as the screen, opus (by a 'normal' supply) etc...
  10. #20
    Quote Originally Posted by JC-S60
    I'll go and try a normal PSU now...
  1. Replies: 15
    Last Post: 10-20-2004, 09:49 AM
  2. Do any keyboards come with RED backlighting?
    By imprezive one in forum Input Devices
    Last Post: 10-08-2004, 09:00 AM
  3. Why MMI Red 800X600 no worky?
    By STI_FFY in forum FrodoPlayer
    Last Post: 06-27-2004, 09:38 AM
  4. Engine whine
    By mobileh1 in forum Software & Software Development
    Last Post: 05-26-2004, 07:28 PM
  5. Headunits with red lights?
    By none in forum General MP3Car Discussion
    Last Post: 03-28-2004, 07:32 AM
