Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Red Red Whine....
    Red Red Whine....
    Everything installed and, but speakers are buzzing and whining, some of it is clearly related to when the hard drive working, and some of it is related to the engine revs.
    The setup -
    Micro Atx board 2.4 celeron, with onboard sound, the speaker line is connected with RCA's to the CD changer, where I have cut the left and right audio feed and attached female RCA's (I hope this is clear)
    The car is powered via cigarette lighter. Opus 150w.
    I have tried lots of different grounding points, nothing makes a difference. I have tried powering it direct from the battery, still no difference, I have tried grounding the case, and the opus chassis, still whining and buzzing.
    It doesn't matter if the ignition is off or not, but if the PC is shut down then there is no noise.
    I have tried plugging the headphone jack that goes into the PC into a portable CD player and everything is fine, no noise.
    I have plugged external speakers into the PC and there is also noise on them.
    Can anyone tell me what to try next, and likely causes given the symptons and test results above.
    Many thanks,
    Matt
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Have you tried grounding your audio ground?
    Tidder
    Try RevFE
    Quote Originally Posted by Tidder
    Apologies for my ignorance, but how do I do that ??
    Thanks,
    Matt
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Try not to power the Opus via the cig lighter. Wire it directly to the battery and use the cig light wire for turn on the Opus (IGN).
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Quote Originally Posted by MatrixPC
    Cigarette lighter is permanently on. So can't do that. Tried hardwiring it to the battery and there was no improvement.
    Do you know how to ground the audio?
    Thanks,
    Matt
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    try grounding the motherboard to the case of the opus?
    CarPC install is starting to come along again...
    Quote Originally Posted by Grayscale
    Surely the motherboard should already be grounded to the case which is grounded to the opus which I tried grounding independently to no avail.
    Can anyone tell me how to ground the audio, or offer any other suggestions ??
    Thanks,
    Matthew
    Sep 2003
    New Mexico, USA
    You ground the audio by splicing into your audio wire, and using it's ground to connect to chassy ground. Fixed some major audio whining in my car.
    Tidder
    Try RevFE
    Newbie Huflungdung5342's Avatar
    Jul 2004
    ground it by exposing a section of the chassis' metal, sand off some of the paint, and attach the ground wire to it
    Constant Bitrate coachreed's Avatar
    May 2004
    Lee's Summit, MO, USA
    You should have your grounds for amps and source (headunit and/or computer) grounded to the SAME point on the vehicle chassis... if that means you have to run an extra ground wire from the front to the rear of the vehicle, you should do it... just keeps from having ground-loop problems where you will most likely pick up noise due to a potential voltage difference. If that made ANY sense.
    Later!
    Coach... aka Randy! (I often forget who I really am!) ;)
    ***Too many pieces and parts to list... maybe someday I'll show'm to ya!***
  1. Replies: 15
    Last Post: 10-20-2004, 09:49 AM
  2. Do any keyboards come with RED backlighting?
    By imprezive one in forum Input Devices
    Last Post: 10-08-2004, 09:00 AM
  3. Why MMI Red 800X600 no worky?
    By STI_FFY in forum FrodoPlayer
    Last Post: 06-27-2004, 09:38 AM
  4. Engine whine
    By mobileh1 in forum Software & Software Development
    Last Post: 05-26-2004, 07:28 PM
  5. Headunits with red lights?
    By none in forum General MP3Car Discussion
    Last Post: 03-28-2004, 07:32 AM
