Results 1 to 7 of 7
Thread: cant get power to amp
    Oct 2004
    Wheeling
    i ran the wire through my firewall and everything is fine.. and then i hook my ground and remote wire up.. then i go to go my power wire and i hook it up fine i go to check if i have power to the amp... NO.. i then redid the ground remote and power wires to my amp check it again NOTHING.. then i think maybe the power light is burnt out.. so i hook up my speaker wire adn then hook it up to my sub.. NOTHING.. got anything for me guys..?
    FLAC migel628's Avatar
    Mar 2004
    New Windsor, NY
    Is your grounding point a straight metal contact w/ no paint in the way? That's a good place to start. Is the power wire secure on the positive battery terminal? Have you checked to make sure the power wire is actually transferring electricity w/ a DMM? Just a few ideas too look into...
    "I'm a dick!"
    "I must seek knowledge and it's bastard son truth" - The State
    Jul 2004
    Are you sure you have 12volts on your remote wire? I know a few radios (not many) have the remote wire fused, check that. Or better yet, jump the remote input to your main power wire and see if it turns on.
    Oct 2004
    Wheeling
    Or better yet, jump the remote input to your main power wire and see if it turns on.[/QUOTE]
    is that safe to do.. or will something blow
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    use a different ground. i was helping a friend install his amp...they couldnt figure out whats wrong, so i came over with my DMM and measured 3 volts. he grounded it to the back seat which really has no good contact to the car chassis. just found a better ground and everything worked perfectly.
    rebuilding carpc... kinda..
    Nov 2003
    CT
    Quote Originally Posted by Murphy3603
    something will blow if you connect the remote wire to the + contact on the amp. you'll be fine though if you connect the power wire to both the + and REM contact on the amp though
    Get a mulitmeter, it will save your hours of testing different problems.
  1. PC Power Supply and Car Amp
    By GezusK in forum Car Audio
    Last Post: 05-10-2006, 01:31 AM
  2. 12v Power Supply at MP3Car.com store
    By mykolJay in forum Power Supplies
    Last Post: 02-02-2006, 10:17 PM
  3. Sound not very loud have i bought the wrong amp
    By rickyaswell in forum Car Audio
    Last Post: 09-26-2004, 11:23 PM
  4. getting an odd motherboard to power on
    By karmann in forum Power Supplies
    Last Post: 11-28-2001, 06:27 PM
  5. HELP!! Power Supply wont supply power
    By Saab in forum General Hardware Discussion
    Last Post: 08-28-2000, 10:33 AM
