Results 1 to 6 of 6
Thread: Car Audio (and computer audio) Guru's I need your help (My Mp3Car Audio is too quiet)
    Variable Bitrate hevnsnt's Avatar
    Mar 2004
    Ok, I have asked about this in the past, but now I have the extra $$ to go ahead and do it.. I am seeking the best (ie cheapest) route.
    Here is what I have
    Jeep Grand Cherokee with Upgraded Infinity System
    (Radio unit with external amplifier and six Infinity 4-ohm speakers. Amp is an Infinity 180w amp, with a factory harness)
    I have replaced the stock radio with a 7" touchscreen connected to a computer. (a la Mp3Car style) and I used a aftermarket "factory" harness to connect my mini-plug computer output into my amplifier. (Harness connects to what used to connect to the radio, and then I have soldered wires to it)
    Now, here is what I want to do. I want my stereo back to the same loudness that I had before. Nothing more, nothing less. I just want my stereo to sound good, doesnt have to be loud (it was loud enough before)
    The problem is I am feeding the amp line-level power (from the computer) into an amp that is wanting a high-input (from the stock stereo)
    As I said, I have asked about this before, and someone mentioned that I get a line driver, but I am not exactly sure what I should get. Now remember I am going to have 2 fronts, and 2 rears. (so 4 channels)
    On ebay I found some like this and some like this. I happen to have a $75 gift certificate to Crutchfield, and I noticed they have these.
    What would you suggest I do here?
    www.i-hacked.com Hardware hacking articles
    Jul 2004
    The first two items you lnked to are LINE DRIVERS, but the Crutchfield item is a Line Output Converter. A line driver will increase the voltage of the signal to the amp. This will help you accomplish what you want. A line output converter takes high level inputs (speaker leads) and converts them into RCAs so they can feed an amp that doesn't have high level inputs. Hopefully this clears it up a little.
    Mar 2004
    cool thanks.. Now what is the difference between the two kinds on ebay.. Are they just different form factor? And since I need 4 chans, I assume I will have to buy 2 of them correct?
    Oct 2004
    NY
    the pg ones are beter than the audiobahns & that seller is sure to have 2 to sell you...
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    I'd look into something more like this, this, or these.
    Fabricator
    DiB
    DiB is offline
    Oct 2004
    Audiocontrol makes some nice gear for this but it's pricey, found this on ebay and it supports a 6.1 system. It's over kill but it will work as a line driver for everything.
  1. Replies: 19
    Last Post: 12-04-2004, 06:37 PM
  2. Complete solution, COMPUTER, SCREEN +DVD player for your car!
    By wrxmaster in forum Classified Archive
    Last Post: 07-09-2004, 03:26 PM
  3. FS: Lots of Computer Parts, Car Audio, Other Stuff
    By smashr2k in forum Classified Archive
    Last Post: 07-01-2004, 06:01 PM
  4. car audio wiring harness -> computer speaker port ??
    By nadir_s in forum General MP3Car Discussion
    Last Post: 01-07-2004, 10:48 PM
  5. cleaning out some computer and car audio stuff
    By allenruble in forum Classified Archive
    Last Post: 12-11-2001, 09:12 PM
