Results 11 to 20 of 22
Thread: My Amp Blew My Sub!
  1. #11
    Constant Bitrate LeoTheHamster's Avatar
    Jul 2004
    Kings Lynn, Norfolk, UK
    Quote Originally Posted by IamMBS
    It doesn't matter what the max watts of the amp or subs are, it's so hard to compare ratings from one manufacturer to another, usually cheap amps are over rated and good quality (expensive) amps are under rated. Just don't overdrive the amp/sub to distort.
    Which is why anyone with any sense should look at the RMS values
    If there not listed, that should tell you something.......
    Leo
    http://www.talkaudio.co.uk
    A million people can't be wrong, right?
    Well... unless they're all from the red states...
  2. #12
    Maximum Bitrate brrman's Avatar
    Aug 2003
    Indianapolis, IN USA
    Quote Originally Posted by LeoTheHamster
    Underpowering speakers WILL NOT damage them, it just means they wont get as loud. If the amp is CLIPPING however, then your dustcap will probably end up the other side of the carpark
    Not until you push the volume beyond its calling limits. Then you clip and boom.
    Car: 2000 Audi A4 Avant 1.8t
    Carputer 2.0: removed. Back to stock.
  3. #13
    Jul 2004
    Quote Originally Posted by brrman
    Congratulations, you just repeated what I said
    Leo
  4. #14
    Maximum Bitrate Snootch's Avatar
    Sep 2003
    Tampa, Florida
    I think the problem is user (install) error, here's some reading material:
    http://www.bcae1.com/amplfier.htm
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
  5. #15
    Aug 2003
    wow - aren;t you a friendly ***** today
  6. #16
    Constant Bitrate chewiee's Avatar
    Kent, UK
    Two words...
    Quote Originally Posted by Dracos
    I dont mean to be nasty mate, but lie down before you hurt yourself. 200w amp and 500w Sub?!?!? you fool. The amp needs to be equal power or greater than the attached speaker. Else, you will get clipping and overdrive which will shred your speakers. Anyone who knows an ounce about audio will know this. Go read up on ohmage and wattage and what amps/subs to use, THEN try installing your car audio. Unless you have loads of money to waste that is..........
    Arrogant c--t... well sorry mate that's how this came across...
    I asked because I don't know... hence me being here and not mensa.com ...
    Cheers for the other suggestions guys.
    Chewiee
    VW Mk2 Golf GTI 16V:
    Kenwood KDC-W6527 HU
    Silver Travla C134, Slot Loading DVD/CDRW,
    256MB, VIA Epia MII 12000, Carnetix 60W, Xenarc VGA/Composite TS and a GPS Mouse
  7. #17
    Variable Bitrate Dracos's Avatar
    United Kingdom
    Quote Originally Posted by chewiee
    Chewiee
    I must offer my sincerest apollogies for that post. I had had a VERY bad day that day and I just kinda vented. Upon reading it myself, I must agree, I was a c--t. Again, sorry.
    D
  8. #18
    Kent, UK
    No Problem Dracos!!
    We're all friends here!
    Still need to sort the amp, I wanna keep it in the Rover 216 Cabriolet, but I've just ordered my xenarc and gps mouse so money's tight... but I'll be all up and running pretty soon.
    I get a Frontera Sport RS on a 1999 (S) plate at the end of the month... and I've got a list of things to do to it as long as my arm!
    Speaking of which... gotta go post elsewhere.
    See Mods, we do split multiple questions into their proper place
  9. #19
    Aug 2003
    *group hug*
  10. #20
    Variable Bitrate mp3hombre's Avatar
    Aug 2002
    Montreal / Los Angeles
    chewiee, in my experience, your amp has probably shorted output transistors (dc at the output like JC-S60 said). I would recomend you have the amp serviced.
  1. PC Motherboard to 1 amp or 2?
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  2. Sound not very loud have i bought the wrong amp
    By rickyaswell in forum Car Audio
    Last Post: 09-26-2004, 11:23 PM
  3. People with NO HeadUnit, Recommand AMP!!
    By camsgs3 in forum Newbie
    Last Post: 07-26-2004, 07:38 PM
  4. Replies: 1
    Last Post: 11-17-2003, 04:21 PM
  5. EPIA M9000 connection to car amp
    By wi77iam in forum General Hardware Discussion
    Last Post: 08-08-2003, 02:37 PM
