Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 51
Thread: Payment made for the answer
  1. #21
    Quote Originally Posted by MatrixPC
    How did you "modded" the CD changer audio signal?
    - Did you find the audio ground from the changer to the HU (normally it doesn't matter that much)?
    - Are you using relay to switch between the CD changer and the computer for sound?
    I did a little the "aux" audio in for my HU a little differnt from your but the same concept "jamp the audio from the cd player to the HU amplifier".
    I used a DPDT relay to to switch the audio signal between the CD player module of the HU and the car PC. After I check for the audio ground from the CD player to the case, well they are the same.
    So I just tap the audio from the CD to the HU case, nope doesn't work, I have engine whining.
    I have to solder the audio from the ground to the PCB ground point. The noise is basically gone (well still there but you have to really listen to it to hear. Road noise and wind noise is much lounder than the engine whine.
    Ok, I did it by simply identifying the audio lines, cutting them at the back from the CD changer and attached female RCA plugs. A little more basic than your method.
    Are you saying that you fixed the problem by grounding the audio from the CD changer line to the same point that you grounded everything else ??.
    And to do this will I need to cut the ground wire from the CD changer end rather than just splicing it ?????
  2. #22
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Did you try grounding your Mobo/PSU to the same spot that the HU is grounded to?
  3. #23
    Quote Originally Posted by antimatter
    Yes....... no difference
  4. #24
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    did you try ungrounding your mobo from everythiing else including the case?
    CarPC install is starting to come along again...
  5. #25
    Quote Originally Posted by Grayscale
    Not yet, that is a huge task when you are using a metal case. Last resort option methinks...
  6. #26
    Jan 2004
    California
    What awg wire are you using?
    I would use 8awg - 4awg wire for power and for ground. Keep your ground short as possible. Make sure all signal cables are far from power cables (i mean all of them).
  7. #27
    Nov 2004
    Lightbulb
    What about plugging the computer in to a regular (AC) power supply and keep the computer in the car hooked up as normal. Then provide power via a long extension cable... turn on the car and rev the engine and see if the noise is still there.
    This will let you know about how your ground in the car is working because you are isolating the computer to it's own power source. It's not that hard to do and it's worth a try
  8. #28
    Jan 2004
    California
    Thats a good test. Although I think we know already that it is either a grounding issue or a inducted noise. I suspect that his power and ground connections are crossing some of the cars internal wiring.
    Another Idea is to run a seperate power line for the Head Unit as well as the CD Changer
  9. #29
    May 2004
    Arkansas
    we already know the ground loop is in the car
    ahh you beat me to it stepfather!
  10. #30
    Jan 2004
    California
  1. Duramix is the Answer for Dash Fabrication!
    By johnram in forum Fabrication
    Last Post: 01-16-2008, 08:42 AM
  2. I made some more things for my carputer
    By turbochris in forum General Hardware Discussion
    Last Post: 07-12-2004, 08:22 PM
  3. soft audio switcher...anyone made one?
    By stimps in forum General Hardware Discussion
    Last Post: 03-17-2004, 02:53 AM
  4. I just made a donation to this guy.
    By churnopol in forum Off Topic
    Last Post: 12-11-2003, 07:47 PM
  5. OK, lets have a final answer!
    By orangewhip in forum Power Supplies
    Last Post: 04-17-2003, 10:27 AM
