Ok, I guess that's right, since we already know it's a ground-loop problem we must isolate where it's coming from exactly.
Here's another idea that might isolate whether it's a car wiring problem or the computer itself causing a grounding problem... Since you have an OPUS you can fairly easily hook it up temporarily to someone else's car (aligator clips to the battery would suffice). Then see if the noise is still there. If it is then you know you have to ground out your computer better!
Or you could just try another computer in your car, but that's a bit harder to do.
LinkBack URL
About LinkBacks
good luck..
