Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Highway Noise
  1. #11
    Aug 2004
    Matthew230, is this something along the lines of what you are suggesting?
    http://www.radioshack.com/product.as...t%5Fid=31-5032
    Do you suggest any particular brand?
  2. #12
    Quote Originally Posted by Socno24
    You could use that, though it is a a good degree of overkill. Plus is you run it from your inverter, you could cause ground loop noise.
    You could probably get away with one of these.
    http://www.boostaroo.com/store_detail.php4?id=1
    Or with the ghettoblaster option, I think they are called boomboxes in the US,
    http://www.sonystyle.ca/commerce/ser...th=32120n32125
    Something like that, but you could find a cheaper one, just remember it has to have a line-in option, (either RCA or stereo Jack)
  3. #13
    Constant Bitrate BassBinDevil's Avatar
    Nov 2004
    Vancouver Island, B.C.
    Is there a way to enable "dynamic range compensation" or "night mode" during DVD playback? Some (most?) home Dolby Digital receivers/decoders have this, which basically compresses the dynamic range so that if you're watching a movie with the volume low you can still hear the dialogue without blasting the neigbours awake when a helicopter crashes. Otherwise, try ear-buds combined with over-the-ear hearing protectors. Or get a pair of airforce-surplus headphones and modify them for stereo.
    I entered my mom's car in DB Dragracing; it took less than an hour to load the dual-18" cabinet in the back of the Toyota station wagon, and run a cable from the battery to the amp. I only got 140.1 dB, but that was enough for one point.
  4. #14
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    My car's got more than enough sound-deadening material to go around
  1. Noise on audio from laptop
    By pip in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 11-24-2006, 08:09 PM
  2. Replies: 86
    Last Post: 04-04-2005, 04:57 PM
  3. noise investigation
    By lookinco in forum Power Supplies
    Last Post: 09-23-2004, 03:41 AM
  4. Noise!! AARGH!
    By sq_geek in forum General Hardware Discussion
    Last Post: 09-21-2004, 02:33 PM
  5. Questiong about noise filter
    By helloman in forum General Hardware Discussion
    Last Post: 11-05-2001, 09:18 AM
