Results 1 to 10 of 12
Thread: Recommend wattage for an AMP
    Feb 2004
    Hey guys,
    So here's the deal. I've designed my system without a HU unit so I'll obviously need an amp. I don't need to power any subs or anything complicated. I've basically got four speakers, two in the front two in the rear. I basically want a decent quality amp to power the four speakers and hopefully be small enough to tuck away where the HU unit was. The quality and power of the HU was fine to me as it was if that helps in terms of making a recommendation.
    Any recommendations would be appreciated.
    Variable Bitrate Dracos's Avatar
    United Kingdom
    we will need wattages of speakers to make an informed decision.
    Feb 2004
    They are stock speakers... lemme check the factory manual.
    Constant Bitrate dingofarmer's Avatar
    Oct 2004
    colorado
    Check out ikesound.com, great prices,
    United Kingdom
    if they arent in the manual, just pop them out quickly, and look on the back of them. A sticker should reveal their wattage and ohmage. Then we can give you some sort of buying guide.
    Feb 2004
    Since I dont' know the wattage and I'm not having any luck finding the info, How many channel amp would I need?
    bakersfield, ca
    a simple 2ch amp wired in parallel would work, just make sure the amp is 2ohm stable which all reputable brands are. 50 watts would be plenty for a simple setup.
    United Kingdom
    well, if you did a bit of coupling up you could easily do it with a 2 channel amp. If you wanted things nice and simple, just go with a 4 channel stereo amp.
    Knowing what stock speakers are normally like, a 400-600w amp should suffice you with lots of room to spare and give you room to upgrade in the future
    Feb 2004
    Okay, stock head unit puts out 67 watts total, stock speakers rated at 25 watts max input.
    Feb 2004
    Quote Originally Posted by Dracos
    I would probably upgrade the speakers at some point for sure. Nothing too great, but decent quality. So I should plan for some room to grow.
  1. PC Motherboard to 1 amp or 2?
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  2. Sound not very loud have i bought the wrong amp
    By rickyaswell in forum Car Audio
    Last Post: 09-26-2004, 11:23 PM
  3. People with NO HeadUnit, Recommand AMP!!
    By camsgs3 in forum Newbie
    Last Post: 07-26-2004, 07:38 PM
  4. Question Concerning fan wattage
    By Scorpnstail in forum General MP3Car Discussion
    Last Post: 03-31-2004, 06:49 PM
  5. Case fan modified. Safe?
    By cafn8 in forum Off Topic
    Last Post: 03-18-2004, 11:57 AM
