Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: 1996 Ford Ranger - Suggestions on Sound Setup
  1. #21
    Oct 2004
    Bay Area, CA
    I decided to take and post a bunch of pictures of my current setup to help get some ideas. You will notice the ground connection behind the drivers side jumpseat that supplies power to the amp - I know it's not the best - it's only temporary... Look around and suggest a way for me to set up the audio system. Thanks! -BMW
    Brett's '96 Ranger Image Gallery
  2. #22
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    You can check out my install as well.. I relocated the head unit and it's very simple to switch from PC to radio... I ended up getting an Explorer full length console and it worked our exactly how I had planned.
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
  3. #23
    Oct 2004
    Bay Area, CA
    Ok, so I see that on your setup you used the aux in on your stereo... How does that sound? That seems to be the logical and best solution, almost too easy .
  4. #24
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    If your still having problems with engine noise coming from your speakers, might I suggest something called a "Ground Loop Isolator". They are pretty cheap here in San Diego. I bought mine at a local car audio shop for $20, and it solved my problem.
    Peace,
    Rafster
  5. #25
    Oct 2004
    Bay Area, CA
    Yeah. I have heard of these. I am not sure that I will continue using the amp though either... I might just get a new headunit with and aux in. Thanks though! -BW
  6. #26
    Oct 2003
    Poland, OH
    Yup.. It sounds great.. No quality loss whatsoever..
  7. #27
    Oct 2004
    Bay Area, CA
    I will go ahead and go this route then and get a deck with the aux inputs. Can anyone suggest a location to mount it since the Lilliput will be in the way of the lold location? I will get a unit with a remotely mountable faceplate... Ideas? Thanks! -Brett W
  1. Replies: 13
    Last Post: 10-28-2004, 07:48 PM
  2. best setup for surround sound?
    By SWC in forum Car Audio
    Last Post: 08-27-2004, 11:26 PM
  3. Replies: 4
    Last Post: 04-18-2004, 11:50 PM
  4. got sound?
    By masch in forum Newbie
    Last Post: 11-17-2003, 10:01 AM
  5. 4-channel sound setup?
    By Phat Justice in forum General Hardware Discussion
    Last Post: 05-16-2001, 10:15 PM
