Results 1 to 4 of 4
Thread: New Sub Box
    Variable Bitrate BiohazrD's Avatar
    Katy TX
    New Sub Box
    Alright guys, I'm going to build a new sub box. I didn't much like the one that came installed when i bought my subs, so I decided to start from scratch. First of all, I am running 2 of these:
    AW120T
    12” EXCURSION SUBWOOFER
    60 oz. Strontium Magnet
    Power Handling: 500 watts RMS.
    Frequency Response: 26Hz - 1kHz
    Efficiency: 92.8 dB
    PHAT 2” Foam Surround
    Non-Pressed, Non-Transfer Paper Cone
    KM3’ Coated for Virtually No Cone Distortion
    2” 4-Layer ASV Voice Coil
    Single 4 Ohm Operation
    Mounting Dimensions: Depth; 5 3/8” Hole, 107/8” Diameter, 12 1/2”
    MULT-CONNECT Lug Lock Terminals
    Linky
    With a Quantum 1000.1 (1000 watts x 1 channel @ 2 ohms). The subs are wired in a 2 ohm stable configuration.
    And I need to know how big of a box i should build (Volume wise), I am thinking about putting these somewhere in the cab of my car for a little extra boom. I am not sure as to wether I want a sealed box, or if I just want to go all out loud (Bandpass box). Any suggestions?
    Quick! To the Popemobile!
    Super Moderator xBrady's Avatar
    USA
    My sub box r0xers! I bought a 10" sub with a box from Walmart, I later got a 12" Kenwood sub so I cut open a bigger hole in my box and wala! I have one rockin box.
    Installed.
    -GPSSecure- - GPS Tracking
    Katy TX
    Y'know, I'm poor enough, cheap enough, and lazy enough to possibly go with that option.
    Newbie John M's Avatar
    Nov 2004
    Milledgeville, GA
    Your box:
    3.3 cubic feet total (internal dimensions), divider in the middle.
    One port on each side, 3in diameter by 8 inches long.
    So, how much do you trust a stranger (and a newb on this foum)? Build this box and I guarantee you'll be grinning every time you turn the knob.
    You will not like these speakers in a sealed box. If you've got them in one now, you really need to try the ported design above.
  1. Wiring Distribution Fuse Box, cable length etc
    By Pabs in forum General Hardware Discussion
    Last Post: 09-06-2004, 05:59 PM
  2. Case design for a stowage box.
    By nibix in forum Fabrication
    Last Post: 07-10-2004, 06:12 PM
  3. Brainstorming glove box PC
    By KingRudy in forum General Hardware Discussion
    Last Post: 06-14-2004, 03:39 PM
  4. M10000n Box
    By mikeyg35 in forum General Hardware Discussion
    Last Post: 04-05-2004, 11:22 PM
  5. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
