Results 1 to 7 of 7
Thread: Lost 12V power after rewire. Help!
    Feb 2004
    Las Vegas, NV
    I've seem to have lost my 12V power going to my headunit sometime during a rewiring project.
    Background:
    2000 Ford Mustang, aftermarket Kenwood head unit installed by Best Buy.
    What I did:
    I wanted to tap the 12V wire to power a mobile monitor. However, sometime during the process I lost power from the factory harness. Now I can't power either the monitor or the head unit, together or separately. I've checked voltages with a multimeter.
    What I've done since:
    I've checked all the fuses in the passenger compartment. I looked up my fuse box diagram and swapped out any fuses that were associated with the radio.
    Any ideas on what happened?
    Variable Bitrate Fox_Mulder's Avatar
    Melbourne, Australia The Truth Is Out There
    Fuses in the engine compartment?
    Fox Mulder
    2001 Toyota Avalon Vxi
    Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
    2004 Toyota MR2
    Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353 DiNovo Mini Car2PC ODBII
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    Check all the butt connectors and see if a wire pulled out? I know how some of those "pro's" install, and it makes me sick. If no fuses are blown, there is a good chance something simply pulled out. Look in the areas that the installer would have messed with.
    2005 Ford Focus ST
    Feb 2004
    Las Vegas, NV
    Quote Originally Posted by gospeed.racer
    Checked the butt connectors myself. In fact, I redid the butt connectors on the 12V and the ground because theirs was sloppy. At least theirs worked.
    Feb 2004
    Las Vegas, NV
    Quote Originally Posted by Fox_Mulder
    I'll take a quick peek, but I'm not sure if there are any fuses there that are connected to the radio.
    Newbie John M's Avatar
    Nov 2004
    Milledgeville, GA
    Are you missing constant 12v or switched 12v? If it's constant, you probably blew the dome light fuse.
    2005 Subaru Legacy GT
    Status: 40% - starting install
    • AMD Sempron 3100, Biostar K8NHA PRO mobo, 512 meg DDR, WD 200 gig SATA, Opus 150, Xenarc
    • JBL GTi 6.5 fr, JBL 5.25 rr, (3) JBL 75x2 & 1 1200x1 amps, PA MOFO 12 sub
    Feb 2004
    Las Vegas, NV
    I went to Wal-Mart and picked up a fuse checker. Turns out one of my fuses in the engine compartment was bad, I just couldn't see it at first. Thanks for all the help.
  1. Car power supply (battery charger) from old pc supply
    By stimps in forum Power Supplies
    Last Post: 08-20-2010, 01:39 AM
  2. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
  3. Power Question/Setup Question, minibook pc
    By seamonkey420 in forum Newbie
    Last Post: 05-17-2004, 10:47 PM
  4. USB2 hub with 12V power supply.
    By blaster in forum General Hardware Discussion
    Last Post: 01-27-2004, 06:29 PM
  5. 12v dc-dc atx power supply
    By plasmadis in forum General Hardware Discussion
    Last Post: 06-28-2000, 05:51 AM
