Results 1 to 3 of 3
Thread: Connecting the EPIA MII 10000 to a car Amp.
    Low Bitrate CherokeeChief's Avatar
    Nov 2004
    Italy
    Hi to all,
    I need to connect my EPIA MII-10000 to a 4 channel car amplifier. From the EPIA I have only the "Line Out" connector. I would like to have just front & rear speakers. How I have to connnect it?
    Thanks.
    Oct 2004
    same kinda issue i have. I am running two amps, 1 - 2ch, 1 - 4ch - my mobo only has line out on it.
    To do it properly, you need to invest in a 4.1 or even a 5.1 surround card, have the 4/5 split as your front and rears into your 4 ch amp. I'm then connecting the .1 port to the 2 ch amp running the subs...
    I thought the Epia MII had 5.1 surround sound?? Usually what happens is you have a front end in your audio drivers that reset the line-in and the mic to be the other channels instead....
    Luke
    Elsewhere
    Quote Originally Posted by CherokeeChief
    Hi to all,
    You can enable the audio connectors to utilize F/R channels through the Line In, if I'm not mistaken. I don't have that board, so I don't know the exact procedure. I'm sure it's been posted here, so doa SEARCH, too.
    How about the Wiki?
  1. cheapest price via epia mii 12000?
    By jdub421 in forum General Hardware Discussion
    Last Post: 10-22-2004, 11:45 PM
  2. WTB: Epia MII 10000,12000 or maybe m10000
    By alti in forum Classified Archive
    Last Post: 10-16-2004, 06:11 PM
  3. Temp monitor program for Epia MII 1k0
    By samc in forum Software & Software Development
    Last Post: 05-14-2004, 06:41 PM
  4. EPIA M9000 connection to car amp
    By wi77iam in forum General Hardware Discussion
    Last Post: 08-08-2003, 02:37 PM
  5. connecting sproggy to car battery
    By apparatus in forum Power Supplies
    Last Post: 01-11-2002, 05:46 PM
