My Rikaline GPS Receiver and Xm Direct Antenna are 2 inches apart and I have no problem whatsoever.Originally Posted by legend5761
Hope this helps.......
Troy
Yo guys,
I am thinking of putting my XM receiver and my GPS receiver by the rear window? Will both interfere with each other?
Troy
I've had no problems with my antennas touching each other on my trunk. I found my GPS worked a lot better outside the car then it did under the front windshield.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
Unlikely, but possible depending on quality of the products. Both are receivers and not transmitters so they should not give off a lot of EMI.
Thanks guys, I too got the Rikaline 6010 and I just ordered a XM PCR unit from HP. Thanks.
There is a problem with GPS and the Roady line of XM receivers....
The original Roady 1 generates a literal ****load of EMI around the same frequency range as GPS. Any GPS receiver within 8 or so feet of a Roady will usually not be able to pick up a single satellite.
The problem was solved in later revisions of the Roady, and does not exist in the Roady 2. If you have a Roady with this problem call Delphi and they will swap it with a newer, fixed Roady.
