Results 1 to 10 of 18
Thread: Buzzing noise when shuttle is plugged in
    Nov 2004
    I have a xbox and shuttle in my car which are powered through a 300w xantrex inverter. when the xbox was turned on, it use to make a very loud buzzing noise until i wrapped some solder around the rca grounds at my zux input adaptor which eliminated the noise. but now with my shuttle, everytime i plug it into the inverter, there is some kind of buzzing sound that sounds like morse code haha. then when i turn it on, there is a very buzzing sound. I also am getting these lines going up my lcd which i cant seem to get rid of. BTW, none of these problems exsist when everything is plugged into a regular wall outlet, and i am sure it is not the inverter because i have tried about 7 inverters and this is the best one yet. someone, please help!
    Constant Bitrate Phobos0001's Avatar
    Dec 2004
    Melbourne, Australia
    im no auto electrician, but i think a ground-loop icolator may help. i had a setup using my n-gauge mobile phone, a pre-amp and PC speakers in my '88 magna and i had a horific buzzing when i pluged the phone to the charger, because that created a ground loop, a negative only short circut if you will...... then again i may be completely wrong... im a noob you see, just repeating advice i was given
    well, goodluck at any rate
    _
    Mar 2004
    Little Elm, Texas
    part of the issue is the fact that you are using an inverter. See, a car produces DC current, the inverter takes that and turns it into AC, when it goes into your computer it then has to change it BACK to DC....I would guess that an XBox would do the same thing since it's essentially a computer as well....
    Without tearing off into your X-box I'm not sure how you would be able to use it without using the inverter.
    So, how far apart are all of these items? Is the Inverter relatively close to the x-box and shuttle? If so you might try moving them further apart in the car (if that's possible), also, where are you power wires run? Are they along side your signal cables? If so, move them apart immediately. Move them apart as far as possible (like opposite sides of the car). You could be getting interference from your power wire crossing over into your signal cables.
    Wall power is going to be cleaner than most any inverter, this is another thing to consider.
    Have you grounded everything correctly? By correctly I mean did you scrape away any paint that might be between your grounding location and the wire? If not, do so. It could be any number of things. Let me know about the few I listed if you get a chance.
    Jan Bennett
    Nov 2004
    that is the thing. the only thing ui grounded is the inverter and taht is to the - of the battery. how do i ground everything else from the computer, xbox and the rca cables? i am guessing i just wrap wire around the rca ground and run it to the ground
    _
    Mar 2004
    Little Elm, Texas
    not sure I understand what you are saying..
    your RCAs shouldn't need to be grounded. The plug its self is the ground. The center of the RCA is the positive, and the outside is the ground. The computer will need to be grounded as well. I know that the power supply has gound wires, but I don't think that they do the job adequately. You should be able to ground to a point nearby. Is the mobo in a case or it is open?
    Jan Bennett
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    I'm gonna treat you like an idiot for a moment--not because I think that you're an idiot, but because I have no idea what your level of knowledge is. If you already know some of this stuff, great:
    Quote Originally Posted by mazda3uzr
    Unless your inverter is under the hood, this is problem #1. You need to run 6-18 inches of cable for your ground, no more ( and no less). An excessively long (or short) ground cable will cause problems.
    Go to radio shack and buy some ring connectors. To ground the computer, take a case screw out--preferably one that holds the the power supply in. Make a cable about a foot long with ring connectors on each end. You don't need to use REAL thick wire, but thicker than regular speaker wire. Put the case screw back in with the ring connector around it. Now find a bolt or screw in your car near your computer that goes into metal (this is VERY IMPORTANT) and take it out. If the area around the hole is painted, clean off the paint with sandpaper or just scrape it off with a screwdriver. Put the screw back in with the other end of the cable you made around it. Now you have a wire that goes from your computer case to a metal part of your car, ta da--it's grounded!
    Ideally, all your devices will be grounded to the same point, including your inverter.
    Once you ground everything properly you won't have to do that.
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    I'M DEBT FREE!!
    I'm now a reasonably successful gunblogger.
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by wizardPC
    This is VERY important actually...can't believe it slipped my mind! Good call wizard!
    Now here's a question for you, what do you do if you don't have a case for your mobo? What if your power supply is a DC-DC plug in power supply?
    Jan Bennett
    Newbie z0rz's Avatar
    Dec 2004
    NW Oklahoma
    First of all, the "morses code" that your hearing is most likely your hard drive reading/writing. Now that can be either on your shuttle or your xbox, but from what I understand it seems to be your shuttle.
    So to trouble shoot this let's start with the basics.
    First take your invertor and computer to the hood, hook up the inventer's neg/pos terminals directly to the battery. Plug it all in and see if she whines. If not then it's most likely a bad ground or maybe a signal wire causing interference (bad ground on shielding). So to fix this, follow what these other guys said. Find a good ground and sand it down. Also if you wanna try wrapping your RCA cables with aluminum foil pretty think, and then ground the aluminum foil (again, find a good ground). I'd also wrap the aluminum foil with electrical tape and then maybe put some heat shirnk over it to make it look a little less ghetto.
    That should hopefully fix the problem. Nothing new here. Just do what everyone else suggested and it should work.
    Edit: If you get into xbox modding, you can possibly use an opus 150watt (or even less) on an xbox. You just have to reroute the the wires. There are diagrams all over the net (xbox-scene.com). I'll test it out sometime (maybe in a few years). my mp3car is far from started. I've just been gathering ideas.
    -z0rz
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by z0rz
    If the RCAs that they are using are even half way decent (read: not the walmart $7 RCAs) then this will be absolutely unnecessary. Cheap RCAs can make or break a system. If you think I'm kidding and you have a set of cheapo RCAs, go buy a set of good ones and plug em in and see if you notice a difference, if not just return them and say they didn't do what you wanted. But I doubt you will return them.
    NEVER go cheap on RCAs...I cannot tell you how many people I have had come to us to trouble shoot their problems all to be traced back to the RCAs...
    Jan Bennett
    Nov 2004
    thanks a lot for your help guys. but one question. if all teh grounds should go to once place, and my lcd and deck are on one end fo the car, and the inverter and xbox are on the other end, then how would i keep a ground that is only about 15 inches? any solutions? i was thinking of using 8 awg for the inverter and maybe 12 or 14 for the case and xbox. what do you think?
  1. power supply buzzing help thing i found... read if u have noise
    By TimW in forum General Hardware Discussion
    Last Post: 02-25-2012, 12:48 PM
  2. Replies: 86
    Last Post: 04-04-2005, 04:57 PM
  3. More details on my buzzing noise....
    By sq_geek in forum General Hardware Discussion
    Last Post: 11-02-2004, 01:46 PM
  4. noise investigation
    By lookinco in forum Power Supplies
    Last Post: 09-23-2004, 03:41 AM
  5. Noise!! AARGH!
    Last Post: 09-21-2004, 02:33 PM
