Results 1 to 10 of 14
Thread: Anyone know A LOT about amps?
    Constant Bitrate ClubFed11's Avatar
    Killa Cali
    I turned over my mtx thunder 250D and took off the back cover, it looks like some of the capacitators may have blown, there is all that crap that are in them, scattered throughout the amp.
    I was wondering, could I just try and replace them, or should I try and send it into a pro, and if so, what is a good place, that don't charge the **** out of you.
    I just bought this off someone, I haven't hooked it up yet, but I am pretty sure it will not work, I bought it for really cheap though.
    2009 Altima 2.5S CVT Dark Slate
    Oct 2004
    by some new caps,,, it is easy to change since they are huge on amps. i change caps all the time in PC motherboard and the one i mess with are like 20 smaller than the one you deal with but i still manage to replace them fairly easily. here's a link for the best capacitor i know off that can work up to 125C and have a lice cycle but have been tested to be guaranteed 50,000 hours at 85C
    http://www.secc.co.jp/retri_e/os_rlt_index_e.html
    Killa Cali
    Well How do I know which ones I need?
    Jan 2004
    Jersey/NY
    I highly suggest that you talk to the person that sold you this, and make sure that they realize it was sold to you like this. And if you can't fix it without paying big bucks, you want your money back.
    If that already happened to the amp, maybe something is faulty in it that you can't fix. If you replace the caps, the same thing may happen again. That's my suggestion at least.
    Killa Cali
    Anybody know about capictators?
    Aug 2004
    Hudsonville, Michigan
    I would take the thing back, IMO MTX makes crap my friend is a big MTX guy but I have fixed his subs time and time again as well as his amps
    Nate
    I know what yer thinkin...did he fire six shots or only five...
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    Quote Originally Posted by kozmo
    i've got a mtx thunder 404, and its been working for a couple of years just fine. however thats not on the high end mtx stuff, maybe the more expensive stuff is more prone to problems
    CarPC install is starting to come along again...
    Aug 2004
    That could be, his is
    Nate
    Killa Cali
    I'm not gonna take the amp back or any of that, I posted here to find out if it is fixable or not.
    Variable Bitrate lerandell's Avatar
    Mar 2004
    Ennis,TX.
    In my experience amp caps this big go because of another problem on the board. A lot of times it is because the output ohm load was too low and the amp finals blow.(thatís the final stage of amp transistors) look around on the board to see if the is any tar looking material close to the transistors. if so there more to repair that just the caps.
    They are always fixable. The question is will it cost as much as a new one with a warranty.
    Really the only way to know is have someone look it over.
    800 225 5689 - MTX Customer Service & Amplifier Service Center
    Randell Kelly
  1. mach 460 amps
    By meth84 in forum General Hardware Discussion
    Last Post: 06-27-2007, 07:28 PM
  2. How many amps needed to power carputer?
    By msumr282 in forum Power Supplies
    Last Post: 12-02-2004, 11:05 PM
  3. I need to some basic information about amps
    By Bust_A_Cap in forum Car Audio
    Last Post: 08-01-2004, 09:31 PM
  4. Amps - more power vs less power
    By eug in forum Car Audio
    Last Post: 05-03-2004, 11:08 PM
  5. Legacy, Pyramid, etc. amps?
    By King_Xerxes in forum General MP3Car Discussion
    Last Post: 02-23-2003, 10:30 PM
