Page 7 of 8 FirstFirst 12345678 LastLast
Results 61 to 70 of 79
Thread: Digital Processing options with 5.1
  1. #61
    Maximum Bitrate wysocki's Avatar
    Mar 2004
    Los Angeles Area
    The Extigy doesn't have a CMSS setting as far as I can see, but it DOES have a button on the unit itself that enables it. The Playcenter (for mp3s) has an EAX button for effects but I'm not using it. I set the bass/treble to max on the mixer which sounds pretty much like I want it. Although I would really like a true eq somehow.
    Epia-M II M10000 Nehemiah WinXP sp2 Travla C134 case Carnetix 1260 power Xenarc 700TS XM Direct Toslink Extigy USB 5.1 Garmin GPS18 Linksys 802.11g wireless Nokia 6230 Bluetooth Memphis Amps Focal Speakers Frontend: RoadRunner
  2. #62
    Variable Bitrate Squid's Avatar
    Jan 2004
    Pittsburgh, PA
    As you can see above that picture.. I state that is from my desktop machine running an Audigy 2 ZS....
    But the Audigy 2 NX has the same screen.. it's just lacking the middle option CMSS 2.
    (and no THX)
    So since the Extigy is all hardware.. u can't control what kinda CMSS it is? Well that's bunk!
    hmm... must.. be... some.. way...
    CarPuter: Dell P3-500 Laptop; D-Link WiFi; Deluo GPS; D-Link Radio; iMac DVD w/ ide2usb
    Audio: Audigy 2 NX; Kicker KX700.5 amp; 20w center amp; Kicker L7 10" Sub
    Display: Lilliput 7" TouchScreen
    CarPuter Install
  3. #63
    Jan 2004
    Pittsburgh, PA
    And yea.. I'm running all the current Creative drivers... and SP2...
    I didn't answer that.. cause that screen is not because of drivers.. but card...
    CarPuter Install
  4. #64
    Jan 2005
    Concerning the EQ - Doesn't WMP 10 have a built in 10-channel? If it is configured by loading it in straight, closing, then running Frodo, won't Frodo use those settings?
  5. #65
    Mar 2004
    Los Angeles Area
    Yes, Frodo basically uses whatever wmp is setup for, I guess, because I use DFX for wmp and it comes up in Frodo too. Don't know how I lived before DFX although it takes an extra 30% of cpu (same that the wmp eq does but the eq doesn't provide half the impact that dfx does).
    However, none of this comes into play for external sources like XM. I'm just glad the Exitgy has a bass/treble that work so well on everything.
  6. #66
    Mar 2005
    Pomona, CA
    does anyone know of the audigy pcmcia version pprocesses the line-in and allows 6 channel output? Someone mentioned it did, but no one confirmed.
    If it isn't, is the only option the extigy?
  7. #67
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    And I have a question, is anyone using optical in from the XMDirect and optical out to a processer or digital amp?
    肚子笑痛了
    S60 Install
  8. #68
    Oct 2004
    Since this thread isn't totally dead yet and has alot of bearing on many carPC sound systems, I thought I'd throw in this link. This is a Flash demo on the Extigy from Creative's site.
    http://www.soundblaster.com/product....asp#easeofuse2
    (hmm...on the preview screen it doesn't show this link right. not sure if it will work, but here it is again "http://www.soundblaster.com/products/extigy/tour.asp#easeofuse2")
    Especially check out the 5 slides under the Multi-Channel Performance section. While the Creative CSRs don't seem to know jack, the demo clearly says that users can experience ALL of their audio in 5.1 using CMSS, including stereo input. Further, it says the system smartly switches between CMSS and true Dolby Digital 5.1 depending on the input. Even better, it says the CMSS mixing occurs in real-time, such as game-playing.
    I've wrestled with digital 5.1 outputs and DTS processors for about 12 hours now. I really think this is the answer (for many of us). If this turns out to be as great as I think it will be, I will be upgrading my home system to this as well.
    Thanks a ton Cletis and Wysocki for your input in this thread. It's made my 12 hours (errr day ).
  9. #69
    Low Bitrate cletus323's Avatar
    Oct 2002
    Maryland
    anytime, haha
    Good find on the flash demo!
    P.S. I'm parting out my setup and have an Extigy for sale in case you are interested.
  10. #70
    Oct 2004
    Are you serious? Gah! I just bought one refurbished on Ebay from Creative.
    I know the Extigy docs say it has a built-in amp, but are you running the outputs to another amp to boost the signal more or is the Extigy volume level good enough?
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 11:54 AM
  2. Car 5.1 Dsp Options Vs Pc 5.1 Dsp
    By port20 in forum Car Audio
    Last Post: 05-29-2006, 02:10 AM
  3. Dolby 5.1 digital in car?
    By aphesis in forum General Hardware Discussion
    Last Post: 10-02-2005, 08:31 AM
  4. Creative Inspire 5.1 Digital 5500 on notebook
    By hkp23 in forum General Hardware Discussion
    Last Post: 04-03-2004, 08:10 PM
