if your sony HU can use the XA-300 adapter then you do have an aux input.
the reason that it works well with carputers is that you will not get noise (no noise from
power supply or from cheap
sound card ) from the pc. it will not give you 5.1 but only stereo. the only true digital to audio would be the use of a HU that can directly read a S/pdif data stream. i have looked for some time for a HU that can do this, so far i have found and purchased one. it is a panasonic Cy-ac300, on ebay they are about $200.00. todate i am not satisfied with this so i am still looking into other options. clairon makes a HU that sells for $1199.95 that has an optical input/output but this uses a propriatary connector. i am looking into making a cable to fit. if i can make this work i will let all that want to know more about it then.
