Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: laptop: which is better, USB audigy or pcmcia audigy?
  1. #21
    Oct 2004
    Atlanta, GA
    Anyone tried one of these ?
    http://www.xitel.com/product_hfl.htm
  2. #22
    Low Bitrate killerfishes's Avatar
    Dec 2003
    I love my NX im just hoping the 12V adaptor for the mp3 players will work for it. Im trying to avoid an inverter.
    now working on my Dodge Dak
    toshiba portege == done
    audigy2 NX == done
    7" flush mount == 0%
    pimp rating == 48%
  3. #23
    Variable Bitrate Squid's Avatar
    Jan 2004
    Pittsburgh, PA
    Quote Originally Posted by killerfishes
    I made my own power supply which works great for the NX...
    It's not a "proper" power supply as it just uses a linear regulator.. so it creates
    a fair amount of heat.. but the voltage is very stable and I have it heatsinked and it gets the job done
    You can see pics of it and the schematic at the link in my signature...
    Also I talked about it in this thread in more detail.
    On a diff note.. Maximum PC this month has a quick review of the Audigy PCMCIA...
    I'll scan it tomorrow and post it...
    CarPuter: Dell P3-500 Laptop; D-Link WiFi; Deluo GPS; D-Link Radio; iMac DVD w/ ide2usb
    Audio: Audigy 2 NX; Kicker KX700.5 amp; 20w center amp; Kicker L7 10" Sub
    Display: Lilliput 7" TouchScreen
    CarPuter Install
  4. #24
    Dec 2003
    thanks thats awsome. Im making a PCB for it soon. If you want one I'll send it to you for the info.
    audigy2 NX == done
    pimp rating == 48%
  5. #25
    Dec 2004
    I highly recommend the M-Audio Transit. It consistently received high marks for sound quality and performance (better than any Creative product, but I don't think the PCMCIA Audigy had been tested yet.). Mine cost less than $70 shipped through J and R after I pricematched it to another website.
    It is not a gaming Audio product but a high quality audiophile device, used mostly by musicians.
    I originally bought it to have a Line-In for my laptop, but I will ultimately incorporate it into a carputer.
    View performance here: http://www.fixup.net/products/benchm...ransit2444.htm
    You get a tremendous reduction in noise by taking the audio out of the PC, just because there is so much electrical noise inside a PC case, even a laptop. Beyond that, it has outstanding DA/AD converters.
    It sounds awesome and has Toslink in/Toslink out, along with analog. About the size of a credit card, but 0.9" thick (fits in your pocket).
    Just like someone else posted about another device, this has analog or optical input through the same jack--cool engineering.
    From the product description:
    Hi-Resolution Mobile Audio Upgrade
    Small enough to fit in your pocket, Transit brings hi-resolution 24-bit/96kHz recording and playback to any USB-compatible computer. Digital I/O lets you transfer pristine audio between your computer and other devices such as MiniDisc and DAT. The digital output can deliver AC3 and DTS from your computer to an external decoder such as a surround receiver*. And the bus-powered design allows you play and record virtually anywhere your laptop can go. Transit is your ticket to ride.
    Features:
    Mobile 24-bit/96kHz USB audio upgrade
    1/8 in. stereo analog/optical digital input
    1/8 in. stereo line/headphone output
    TOSlink optical digital output allows AC3 and DTS pass-through*
    Line/optical input accommodates self-powered stereo microphones
    Includes 3.5mm (male) to TOSlink (female) adapter
    Technical Description
    Dimensions: 2.2 x 3.6 x 0.9 in.
    Weight: 1.6 ounces
    Minimum System Requirements:
    For the PC:
    UDMA, EIDE or HDD
    Windows 98 SE/ME/2000/XP
    96kHz Operation: Pentium III 500 mHz, 128 MB RAM
    48 kHz Operation: Pentium II 400 mHz, 64 MB RAM
  6. #26
    Newbie SpacemanSpiff's Avatar
    Jan 2005
    London
    A man after my own heart! I heartily concur!
  1. Opus + Laptop + accessories? Or better solution?
    By Will Albers in forum Power Supplies
    Last Post: 01-30-2005, 02:29 AM
  2. Problem with PCMCIA and USB
    By DjBac in forum General Hardware Discussion
    Last Post: 12-21-2004, 07:17 PM
  3. USB Power problem please help
    By Uconnputer in forum Power Supplies
    Last Post: 12-06-2004, 11:29 PM
  4. Getting 5V out of a laptop using USB
    By dameska in forum Power Supplies
    Last Post: 09-29-2004, 10:57 PM
  5. does anyone know where i can get a pcmcia card with usb and ethernet?
    By chris in nh in forum General Hardware Discussion
    Last Post: 06-27-2004, 05:01 PM
