Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: laptop: which is better, USB audigy or pcmcia audigy?
    Jan 2005
    Berkeley, CA
    looking at using an inspiron 600m for a carputer -- what do people suggest, the usb audigy or the pcmcia one? they both seem to have about the same specs -- although since the USB one has a remote, do you think I could use a PAC switch to control the volume with my steering wheel stereo controls?
    2005 m3 coupe, carputer to come...
    Low Bitrate killerfishes's Avatar
    Dec 2003
    pcmcia if your laptop has the guts. im having truble powering my Audigy NX. also the remote is IR so you will need to have the box sitting out some where.
    EDIT: i did not read all the way thrue. I dont know about the PAC but it would be nice. I dont see why not.
    now working on my Dodge Dak
    toshiba portege == done
    audigy2 NX == done
    7" flush mount == 0%
    pimp rating == 48%
    _
    Mar 2004
    Little Elm, Texas
    no idea on the PAC unit, but the PCMCIA card is a better card for sound quality, the in and outs are TRUE optic....even though it says 1/8" phonojack, according to Creative when I emailed them about it, it's a true optic out, just with the metal ring around it to make it phono capable.....all you need is a 1/8" phono to tos-link adapter.....this is what I am doing in my car since my mobo has a pcmcia slot....haven't had a chance to try it out yet though....will be posting my findings once I try it though!
    Jan Bennett
    Jan 2005
    Berkeley, CA
    cool thanks guys -- assuming i went with pcmcia, is there any way to get my stereo volume control hooked in?
    Variable Bitrate Squid's Avatar
    Jan 2004
    Pittsburgh, PA
    Quote Originally Posted by Red GTi VR6
    Could you explain that better?? I don't understand how u can take a physical
    metal connection (1/8" phono) to a toslink optical? unless your speaking of an actual
    optical to coaxial conversion board... but then the inputs on the card are not OPTICAL...
    Plus I've only seen coax to optic converters that require 110v...
    Just curious.. was thinking of switching to this card to see if it cures the LINE-IN probs
    I have of my radio only coming out of my front 2 speakers....
    CarPuter: Dell P3-500 Laptop; D-Link WiFi; Deluo GPS; D-Link Radio; iMac DVD w/ ide2usb
    Audio: Audigy 2 NX; Kicker KX700.5 amp; 20w center amp; Kicker L7 10" Sub
    Display: Lilliput 7" TouchScreen
    CarPuter Install
    Newbie SpacemanSpiff's Avatar
    Jan 2005
    London
    I don't know why everyone seems to like Creative, in my experience of their PCI cards they're terribly noisy and generally rubbish, if I was looking for a PCMCIA card I'd go for: http://www.turnkey.co.uk/tkweb/stock...GO&context=WEB or USB http://www.turnkey.co.uk/tkweb/stock...FX&context=WEB I know they're english links, but you know there are better sound cards than creative... just my 2 cents
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    They are quite nice - never seen em before. I like the volume control. Could take the card apart and hook it up to your dash but probably a bit risk with a 90 card!
    Jan 2005
    London
    Yeah that PCMCIA card from Echo is really nice, I used a similar version which had 1 in a 1 out on it for audio on my laptop, (the one in the link is just audio out), was very impressed. Pay for quality, you won't be disappointed! Compared to a creative it's miles apart, much better.
    Mar 2004
    Bristol
    seems as though they ar eonly stereo out. would want to get a 4 channel hooked up to an amp so i could alter the fade and balance from the PC.
    Jan 2005
    London
    http://www.turnkey.co.uk/tkweb/stock...RO&context=WEB though I think I might of blown your budget at 175.99!! Still nice.
  1. Opus + Laptop + accessories? Or better solution?
    By Will Albers in forum Power Supplies
    Last Post: 01-30-2005, 02:29 AM
  2. Problem with PCMCIA and USB
    By DjBac in forum General Hardware Discussion
    Last Post: 12-21-2004, 07:17 PM
  3. USB Power problem please help
    By Uconnputer in forum Power Supplies
    Last Post: 12-06-2004, 11:29 PM
  4. Getting 5V out of a laptop using USB
    By dameska in forum Power Supplies
    Last Post: 09-29-2004, 10:57 PM
  5. does anyone know where i can get a pcmcia card with usb and ethernet?
    By chris in nh in forum General Hardware Discussion
    Last Post: 06-27-2004, 05:01 PM
