Results 1 to 5 of 5
Thread: Creating a RCA switch
    Nov 2004
    I was wondering if there is any way to create a custom rca switch to switch sources for rca audio since i only have 1 input on my deck and do not want a regular switch from radio shack or something due to the fact that they are big, and dont do a very discrete job
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    Yes. LED chaser IC (4017), some resistors, and some transistors. And then you can add whatever momentary switch you want.
    Pretty simple stuff. I built one, never made it into my car though.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    FLAC NiN^_^NiN's Avatar
    Aug 2004
    Australia, Melbourne
    I just use a 3 or 2 way switch and hook the audio up to that and keep the ground connected to all so all you doing is switching the audio
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
    Nov 2004
    South West
    couple of 5 pole realys will do, feed the sources into the switching contacts and the output from the common. use any switch you like (or the pc etc) for the coil. connect all the grounds together.
    Nov 2004
    well i have no experience will relays. can someone maybe draw up a quick diagram of how to make something like this?
  1. Capture GPS data at the flip of a switch
    By Mr. Inquisitive in forum GPS
    Last Post: 02-02-2005, 07:06 PM
  2. Savage Switch Botton Group Buy via UK's Iconstyling.com....
    By TheBigDog in forum General Hardware Discussion
    Last Post: 07-21-2004, 11:51 AM
  3. Need clairification on wiring on/off switch
    By syclone477 in forum Newbie
    Last Post: 03-23-2004, 05:59 PM
  4. Help With Extending Laptop Docking Station's Power Button
    By JeffesonM in forum General Hardware Discussion
    Last Post: 04-14-2003, 02:13 AM
  5. ATX power switch
    By mtmsol in forum Power Supplies
    Last Post: 05-13-2001, 01:22 PM
