Results 1 to 9 of 9
Thread: VIA M10000 on-board audio input problem
    Jan 2004
    Champaign, IL
    Looked everywhere for a solution (including VIA Arena), no luck, so:
    The on-board audio inputs on my M10000 are not working, and I need to make this happen (cannot use Extigy for audio input for my application). I have looked at ALL of the settings, confirmed that my microhpone is working fine, but still no joy. Smart 5.1 is not enabled and audio output is working fine. I am using the latest driver from the VIA website (Vinyl AC '97).
    Anyone know how to fix this?
    _
    Mar 2004
    Little Elm, Texas
    inputs? so you are putting soud INTO your computer from a source outside of it? like XM or something along those lines? Or are you talking about the audio OUTPUT to send the signal out to your system?
    Jan Bennett
    Jan 2004
    Champaign, IL
    Thanks for the reply. *Input*. I am trying to use the input on the on-board audio for a microphone. It's not working. I'm just looking for someone that knows that there's works fine on a M10000 so I can find out what driver, etc.
    I use an Extigy with upmixing for output to my system. XM is optical into Extigy. That's all working fine. I unfortunately can't use the input on the Extigy for a microphone, so I need to use the onboard audio.
    _
    Mar 2004
    Little Elm, Texas
    i know that when i had my m10000 it worked....thats all i got for ya though...lol
    Jan Bennett
    Variable Bitrate drait's Avatar
    Dec 2004
    NorCal
    Mine works fine for input as long as it's not set to Smart5.1/Magic5.1 and the Mic volume isn't muted in the volume control app.
    Maybe a bad board?
    You might also want to check the BIOS.. I'm not 100% sure, but I thought I saw something in there regarding the whole magic sound crap the board comes with.
    Jan 2005
    When using the input on the Extigy, does the carpc have to be on to work??? Meaning would the 5.1 output work to an amp if the carpc is not on ?
    thanks
    _
    Mar 2004
    Little Elm, Texas
    how would it have any signal to send to the amp if the carPC wasn't on?
    Jan Bennett
    Jan 2004
    Champaign, IL
    Quote Originally Posted by drait
    Maybe a bad board?
    Thanks, checked BIOS, no luck there. Most likely a driver issue, would you mind confirming with me which driver you have installed? I know everyone is running these boards but you're the only one who replied with these details. I have the most recent VIA driver, I can always reinstall. Appreciate the help.
    Quote Originally Posted by eddiesbu
    thanks
    I believe all of the audio computation for the Extigy is handled by the board, not by any software. So it should 'pass through' audio from the Extigy inputs. Yup, just connected a PDA to the 'Line in' on the Extigy, disconnected the USB port to the computer, sound comes out of the Extigy.
    Jan 2004
    Champaign, IL
    Anybody help, please?? Which drivers work??
  1. Pioneer AUX input problem
    By grunar in forum General Hardware Discussion
    Last Post: 12-02-2008, 02:43 AM
  2. win2k and m10000 audio
    By prometheusg in forum General Hardware Discussion
    Last Post: 10-15-2004, 02:15 PM
  3. DVD Audio problem playing through mediaengine
    By typeshlude in forum Media Engine
    Last Post: 07-20-2004, 09:41 PM
  4. EPIA on board gfx + 7" widescreen LCD = problem?
    By phoTToniq in forum General Hardware Discussion
    Last Post: 06-23-2004, 07:12 PM
  5. www.Crucial.com lists ddr3200 512MB ram for M10000 board. Will it work??
    By brrman in forum General Hardware Discussion
    Last Post: 09-30-2003, 11:00 AM
