Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Multi-Channel Amp/Differing Resistance Spks
    Constant Bitrate ChaCha's Avatar
    Nov 2004
    Los Angeles
    I'm interested in the Audiobahn A5100T 6-channel amp. It runs at either 2 or 4 ohms. http://www.cardomain.com/item/ABNA5100T?ref=bizrdf
    I have Infinity Kappa components, 2-ways & coaxials at 4-ohm and am looking at a Rockford Fosgate Punch 3 sub at 2 or 4-ohm.
    Question: can I have the amp send a 2-ohm signal to the sub and 4-ohms to the other speakers?
    Low Bitrate justin146's Avatar
    Feb 2001
    Oxford, MS
    Yes, you can run it like that.. you should be able to run one channel at 2ohms while the other two are at 4ohms. That amp looks way overpriced for what it is.. $1150?? that is like $50 a pound.haha
    Turbocharged 2000 Explorer 5.0 AWD, SCT tuning software, Carputer w/ Athlon XP2600 and 8" Lilliput custom molded into dash, Terk Commander XM, Rand McNally and MapPoint, bluetooth, and 802.11x
    _
    Mar 2004
    Little Elm, Texas
    for an audiobahn it's overpriced.....but then again, it doesn't take much to make an audiobahn overpriced IMO...=]
    and yes, you can run one channel on 2ohms and another on 4, as long as the amp is designed to take the ohm loads that you are giving it
    Jan Bennett
    Nov 2004
    Los Angeles
    I found one for $599...just used that link for pics and general info. thx for the replies.
    _
    Mar 2004
    Little Elm, Texas
    sweet!
    Jan Bennett
    Registered User belezeebub's Avatar
    Dec 2003
    Not sure
    Not really sure the only place I have seen AudioBahn are on e-bay the specs seem ok for the price but are they good amps or are they just renamed Daewoo, kenford or rockwood like you get at the local flea market
    I tend to use
    Alpine, PPI, OLD Phoenix gold, and once and a while a Old soundstream ref 405 or 705
    Quote Originally Posted by ChaCha
    I:
    _
    Mar 2004
    Little Elm, Texas
    audiobahn = a copy cat company for hte most part. If you look at their lineup then look athte rest of the market they take the most popular stuff out there and make their version of it. It's cheap, it's blinggy, and it's a knock off....
    but it sells, and it sells well.....kinda sad, but if you look at the current culture, you won't wonder why....
    I've always been of the mind that if you have to make something flash to sell it then you must be covering up for poor quality.....but that's just me
    Jan Bennett
    Nov 2004
    Los Angeles
    Red,
    So in your opinion, what would be a better alternative to the Audiobahn amp. The only reason I like this one is because it seems to put out adequate power. All the other 5.1 or multi-channel amps seem to suck with respect to power. Aside from that combo Alpine amp/dsp, what would you recommend? Also, would it be redundant to go with an amp with a built in dsp since I'm already planning on using the Audiobahn ADD51T dsp for d/a conversion, pre-amp boost to 9v per channel? Any thoughts?
    _
    Mar 2004
    Little Elm, Texas
    why are you stuck on a 5-channel first of all?
    just curious
    there might be a better option out there for you with more power and more control is all
    with the speakers and stuff that you have you really don't need gobs and gobs of power
    one thing to remember is that cheaper companies also find ways to bloat their ratings a bit.....take a look at the voltage that those numbers are rated at....is it anything like what you would actually see in a car? sometimes they rate them at like 18v.....which is honnestly lude....lol
    Jan Bennett
    Nov 2004
    Los Angeles
    I want a 5.1 pure digital (fiber optic) system
    TOSLINK out from PC
    TOSLINK in to DSP
    RCA to AMP
    In my noob opinion, it just seemed like an easier install to run power wires to one amp vs. two. I also wanted to mount both the amp and carPC under the seats in the second row and therefore didn't want to cram too many components there.
    I'm open to suggestions though...I think I asked this, maybe in another thread, but since I'm planning on using the Audiobahn ADD51T d/a converter/dsp, would using that Alpine amp you mentioned with theatre surround for about $1000 be redundant since that unit has a built in processor as well?
    By the way, I've read a lot about this stuff here and on other forums but I've never done a car audio install. I'm not nervous about it, but definitely aware that I don't know **** from experience
  1. FP Feature Requests
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-15-2004, 02:19 PM
  2. centre channel
    By Azh2004 in forum Car Audio
    Last Post: 06-24-2004, 07:19 AM
