Page 1 of 7 1234567 LastLast
Results 1 to 10 of 64
Thread: Digital Output - Amps?
    Maximum Bitrate nFiniteTuning's Avatar
    Tijeras, NM
    My shuttle has Analog and Digital 6-channel audio...It gives Dolby Digital, Dolby PRO LOGIC ll, and DTS decoding...which Is absolutely amazing since I have only experienced DTS in movie theaters, and now I have it on my pc.
    But how do I go from the Digital SPDIF output to the amps? I was going to go with a digital amp...but every digital amp I have found is discontinued. Do I need to get some Digital-to-analog processor or somethin?
    1987 Pontiac Fiero GT
    XPCarputer Coming Soon
    [IIIIIII---] 70% Complete
    XPC Model SN41G2V2
    AMD AthlonXP 1800+
    2× Mushkin 256MB DDR
    Pioneer DVDRW
    80GB 7200RPM UltraATA HD
    Windows XP MC2005
    XM Satellite Radio
    •ñFïnïtε Τחטіתģ•
    Constant Bitrate ChaCha's Avatar
    Nov 2004
    Los Angeles
    I think you have to send the signal to some sort of processor/eq so the output level going into the amp gets increased from the low level of the computer. I'm using an Audiobahn ADD51T 5.1 surround sound processor that will be fed with SPDIF from the computer, then sent to the amp via RCAs. Plus I get a great rotary knob for volume.
    Tijeras, NM
    Hmm really....got a picture of it?
    Now I'm wondering what would be better to use...the SoundStorm software for my onboard Digital Sound Card...or just uninstall all the audio software and install the soundcard with just the drivers and have everything go through a sound processor like that.
    XPC Model SN41G2V2
    AMD AthlonXP 1800+
    Pioneer DVDRW
    Windows XP MC2005
    XM Satellite Radio
    •ñFïnïtε Τחטіתģ•
    Variable Bitrate FyreDaug's Avatar
    Jan 2005
    Saskatoon, SK
    Or a home theater amp? I donno, its what I'm using and have no problems.
    Tijeras, NM
    Home theater amp inside of a car? That ruins the meaning of running these small computer systems, to have a huge *** home amp.
    XPC Model SN41G2V2
    AMD AthlonXP 1800+
    Pioneer DVDRW
    Windows XP MC2005
    XM Satellite Radio
    •ñFïnïtε Τחטіתģ•
    Nov 2004
    Los Angeles
    http://www.audiooutfitter.com/store/ADD51T.html
    That's a website with info & pics. I found one on Ebay for $299 (a great price) and the seller seems to have a reputable biz going. I haven't rec'd it yet. When I do I'll post my own pics.
    Low Bitrate lcaruca97's Avatar
    Jun 2004
    Quad Cities Il.
    you will need a D/A converter (digital to analog). I would recommend using a usb sound blaster device because of the ease of use and the fact that there is no hum if you power it with the computers psu.
    Nov 2004
    Los Angeles
    The Audiobahn ADD51T converts the digital to analog. Love the avatar.
    Variable Bitrate lawrence's Avatar
    Oct 2003
    carol stream illinois
    try a look at the clairon drz9255
    it is a am/fm/cd with a optical input/output
    this is what i have been looking at, it a but high $ 1199.00
    but fits my needs, only have to figure out how to spilce an optical
    cable. as the unit uses a propriatary cable end.
    Features:
    Dual 24-Bit/96kHz Sampling DACs and DSP
    Burr-Brown DACs
    Plays CD-R and CD-RWs
    Built-In 4-Way Crossovers (Subwoofer/Low/Mid/High)
    5-Band Parametric Equalizer
    Digital Time Alignment for Each Line Level Output
    4V/8-Channel Gold-Plated Line Level Outputs (for SW/L/M/H or Front 2-Way/Rear/SW) With OFC Cables
    Copper-Plated Chassis
    DC /DC Converter
    CeNET Control of Optional TV Tuner, DVD Changer and 6-Disc CD Changer
    Multi-Changer Control
    Two 2-Channel Aux. Inputs
    Fiber Optic Input/Output
    Vacuum Florescent Display
    IR Remote Control
    Line Level Output Only (Requires External Amplifier)
    Radio Tuner With 18FM/6AM Presets
    Ultra Precise Rotary Volume Control
    Zinc Die-Cast Faceplate
    Tijeras, NM
    AHAHAHA....Lawrence...the reason I have a high end computer for a carputer, is to stay away from that.
    lcaruca97, I have no hum on my system. Just for your info, this onboard sound isn't a cheap setup like whats on the mini itx boards. Its powered by nVidia's nForce Chipset.
    and I'm sure with a Sound Processor I wont have any sound at all except for whats supposed to go out.
    ChaCha, That is amazing. I love it.
    XPC Model SN41G2V2
    AMD AthlonXP 1800+
    Pioneer DVDRW
    Windows XP MC2005
    XM Satellite Radio
    •ñFïnïtε Τחטіתģ•
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. Digital Output and Mic In/Line In
    Last Post: 05-18-2006, 12:36 PM
  3. Audigy 2 NX Dolby Digital with optical output
    By DjBac in forum Car Audio
    Last Post: 11-01-2004, 12:31 PM
  4. XMDirect Digital Audio Output ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 10-11-2004, 09:10 PM
  5. Digital Amps?
    By ptk in forum Car Audio
    Last Post: 08-30-2004, 11:25 PM
