Results 1 to 5 of 5
Thread: Line out Vs Digital out
    Registered User belezeebub's Avatar
    Dec 2003
    Okay here is the question I think I have narrowed down the noise and I am moving on to step two
    should I use my current amps
    PC to Line Driver to Amps
    or get an amp with a Tos input
    (like the Phoenix Gold OCTANE-R 5.1MT see below)
    PC to Amp via Toxlink or Optical
    Looking for Clean clear sound I know each part you add will add in some noise so this is a good battle for the K.I.S.S. theroy
    Pros with using the current amps
    I have them already
    More power
    High end amps
    Cons Line level output from a SB card is low would need a line driver ?
    Pros with new amp
    Full digital signel path little or no noise
    Cons
    A lot less power
    6 channel power amplifier
    12dB LP variable crossover
    24dB HP varibale crossover
    24 bit AD/DA processing
    Dolby Digital 5.1 / Pro-Logic decoding
    Phantom 4.1 processing
    6 independent channel level controls
    Full GUI menu for on-screen control
    Test tone levels for all channels
    Digital toslink (fiber optic) input
    Digital coaxial input
    2 selectable analog input
    IR eye for remote control (included)
    Remote turn-on output for other devices
    Dimensions: 10.0L x 6.0W x 2.0H
    100W x 5 (4 ohm stereo) +
    200W x 1 (4 ohm mono)
    max power
    Top Ramen lgbr's Avatar
    Feb 2004
    Spokane, WA, US
    I'm also on the look out for this. My motherboard has SP/DIF output and I want to take advantage of it. I've tried using optical output from my xbox and believe me, it sounded totally awesome.
    Audio Rockford Fosgate: 900 Watt 4-channel amp, 501bd Mono amp
    Computer AMD 2400+ XP, 1 GB DDR RAM, Orbit Micro 250W DC-DC PSU
    Head units are for cheaters!
    sure some girls fake orgasms.....but it's guys like me who fake the whole relationship
    _
    Mar 2004
    Little Elm, Texas
    clear and clean sound does not = Phoenix Gold, not really close even
    what speakers are you listening to this on? stockers or aftermarket?
    boost the signal as it comes out of the mobo/sound card with an eq or something of the nature. Boost it up to something in the range of 4+ volts, then from there go to your amps.
    Jan Bennett
    Dec 2003
    Currently I have
    2 Sets of Infinity Kappa Perfect 6.1 6.5" 2-way component speaker system.
    Precision Power PCX-480
    2 Infinity Kappa Perfect 12D VQ Subs
    Precision Power PC21400
    But I have been considering scaling down to a single 5 or 6 ch amp.
    Quote Originally Posted by Red GTi VR6
    _
    Mar 2004
    Little Elm, Texas
    if you are running PPI ams don't throw a Phoenix Gold product in there just because....look around a bit and you will be amazed at what you can find....=]
    Jan Bennett
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. XMDirect Digital Audio Output ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 10-11-2004, 09:10 PM
  3. Techies - matching line output levels ???
    By slushieken in forum Car Audio
    Last Post: 09-10-2004, 04:57 PM
  4. Question on Line Out of M10000 and Audigy NX
    By Mears in forum General Hardware Discussion
    Last Post: 06-10-2004, 05:00 AM
  5. Easy way to mute/unmute line in ?
    By liquid_smoke in forum General Hardware Discussion
    Last Post: 12-31-2003, 02:02 AM
