Results 1 to 4 of 4
Thread: Ground issues... need ideas
    Jun 2004
    Ok... I just did some major revamping of my carputer setup. I got rid of my head unit and am now using an Empeg Riocar MP3 player (awesome unit btw) as my heda unit and it goes straight into my amp. The Riocar unit has line in jacks and I had previously just ran the PC line out into the RCA jacks of the Riocar line in. But I just got XM installed also at the same time using an XM direct and using Frodoplayer to control the XM. Here's where it all gets interesteing. I live in the midwestern US and the temperature extremes (0 lowest in winter and 100 or so in the summer) sometimes prevent me from using my car pc. But I still want to have XM available. So I bought the XM commander also to use to control the XM but I also needed to run the XM output to the Riocar line in. I used a splitter to do this. But when I have both computer and XM connected I get a volume drop I've found generally associated with a ground or phasing problem. Due to my setup, I need to find a way to make this work... anyone have any ideas
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    how is it a Ground issues?
    Jun 2004
    hmm... ground on computer audio is not same as ground on XM audio... basically it's like an out of phase thing that kills the sound level... Hence GROUND ISSUES
    Newbie John M's Avatar
    Nov 2004
    Milledgeville, GA
    Nope. You're dividing the output voltage into 2 receiving devices so each gets half. You need an amplified splitter or distributor of some sort to maintain signal levels.
    2005 Subaru Legacy GT
    Status: 40% - starting install
    • AMD Sempron 3100, Biostar K8NHA PRO mobo, 512 meg DDR, WD 200 gig SATA, Opus 150, Xenarc
    • JBL GTi 6.5 fr, JBL 5.25 rr, (3) JBL 75x2 & 1 1200x1 amps, PA MOFO 12 sub
  1. Replies: 0
    Last Post: 12-02-2004, 02:48 PM
  2. Finding good ground to prevent Ground Loop
    By lookinco in forum Power Supplies
    Last Post: 11-04-2004, 02:23 PM
  3. A few Medicar Issues and ideas.
    By Custommx3 in forum MediaCar
    Last Post: 03-01-2004, 04:29 PM
  4. Turtle Beach Santa Cruz Sound Card GIVES me a ground loop?
    By rmjjensen in forum General Hardware Discussion
    Last Post: 11-15-2003, 08:26 AM
  5. Question: Arise psu: ground, neg, and pos.....?
    By Tony S in forum Power Supplies
    Last Post: 05-02-2001, 08:54 AM
