Results 1 to 2 of 2
Thread: RCA dynamic voltage range...?
    Dec 2004
    i am having difficulty choosing a set of amps for my vehicle. Lacking a multi meeter i have no idea how much voltge is output from a computer's soundcard on each channel. Does anyone know the range? does teh sound card effect it?
    Gigabyte nForce2pro (rev. 2) onboard sound
    amps in question take a range of 150mv to 4v
    or 120mv to 5v
    depending on set i get
    Any idea guys? Im tryin to prevent clipping and burining out things if i can.
    Thx alot
    _
    Mar 2004
    Little Elm, Texas
    from my testing - the ONBOARD sound puts out only .5v
    you will want to boost that voltage to an acceptable level. I used an Arc Audio PEQ-7 which is an eq, it boosted my voltage to 9v. Doing so will give you a much cleaner sound. You also won't have to worry with trying to find an amp that matches your output voltage of your sound card.
    In general, i think that you are looking at this with too technical of a mind...lol
    just pick an amp that you like, and get something like an eq or other that will boost your voltage level to an acceptable level...
    Jan Bennett
  1. Replies: 7
    Last Post: 01-14-2005, 11:56 AM
  2. Bug Reports 1.09
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-22-2004, 11:24 PM
  3. What Gauge wires do I use?
    By Showmehow in forum Newbie
    Last Post: 07-25-2004, 11:41 AM
  4. Voltage issues with ITPS?
    By mcrussell in forum Power Supplies
    Last Post: 06-06-2004, 11:48 PM
  5. DC-DC psu and high capacity HDD
    By GrahamS in forum General Hardware Discussion
    Last Post: 12-19-1999, 06:44 PM
