Results 1 to 10 of 12
Thread: Problem with FM Modulator!
    Jan 2005
    Coventry, UK
    Hi Guys,
    I have just bought an FM Modulator while I save up for a decent amp and I have wired this in finally and the sound works a treat! The only thing is, when I use the modulator the screen goes distorted! Could this be inteference from the 2 sound cables (white and red) to the yellow video cable which goes into the screen?
    If it is, how can I prevent this?
    Poom
    Mar 2004
    Not sure on that, but I am going to be hooking up a similar situation tonight or this weekend. I'll let you know how mine goes.
    Jan 2005
    Coventry, UK
    It seems to work on some programs and games but not others!
    Even when the FM modulator is not powered but the Audio cables are plugged into this it still happens but as soon as they are unplugged it works again!
    Does anybody have any ideas?
    Constant Bitrate CornToeGoblin's Avatar
    Dec 2004
    Texas
    Are the wires really close to the monitor? I'm thinking you might have some kind of magnetic field going through those wires. Try with a different type of wire. Other than that i can't think of anything else.
    Try to post a picture of how it gets distorted.
    2008 Civic... Sound system... then carputer install...
    WORK IN PROGRESS
    If you look at my avatar closely, you can see a chick with two big knockers....
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Check all your grounding wires.
    TruckinMP3
    Read the FAQ!
    Jan 2005
    Coventry, UK
    I just checked the ground wire for the FM modulator and I cut it so Ican get a decent earth on the chassis somewhere and the modulator still appears to work when there is no ground wire connected?
    Everything else (Inverter and screen) is using the same earth as I am using a 3 way cigerette lighter adapter! Would this make a different if I earthed this to the chassis also?
    Jan 2005
    Coventry, UK
    Just tried this with a DVD player (house type) and it worked fine! So I put it down to the Xbox!
    Newbie david_liz's Avatar
    Jun 2003
    What modulator do you have? I'm looking for one, and don't know exactly which to buy. Thanks!
    Quote Originally Posted by david_liz
    david_liz, i've tried a couble of FM modulators with varius problems... finally end up with this one http://www.cartft.com/carpc/catalog/il/393
    Works great for me.
    - CarPC: Lilliput 7" Touchscreen, VIA EPIA M10000, 512 MB, 40 GB HDD
    - Install: 90%
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    That's not just a modulator, that's a transmitter!
    The distortions seem like a ground-issue, as Truckinmp3 said, check that.
    The modulator will work without a ground-wire as it gets the ground over the soundwires, which creates a ground-loop, not good.
  1. Tape adapter or FM modulator?
    By kefka_killer in forum Car Audio
    Last Post: 08-26-2004, 02:03 AM
  2. FS : LineX USB FM Modulator
    By Stavros in forum Classified Archive
    Last Post: 02-06-2003, 01:05 PM
  3. FM Modulator Antenna Hookup Question
    By grandamp3 in forum General Hardware Discussion
    Last Post: 01-21-2003, 11:44 PM
  4. fm modulator problems
    By cruzc_99 in forum General MP3Car Discussion
    Last Post: 01-14-2002, 09:29 AM
  5. Which one is better? FM Transmiter or FM Modulator
    By helloman in forum General Hardware Discussion
    Last Post: 03-12-2001, 10:15 AM
