Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: PCI Audio vs. USB Audio vs. Onboard Audio
  1. #11
    Constant Bitrate BassBinDevil's Avatar
    Nov 2004
    Vancouver Island, B.C.
    I don't think a USB outboard device can be that much of an improvement over a PCI card. It's still being fed dirty 5V through the USB cable from the PC, and shares a common ground with the PC. Balanced output from a PCI or USB device would be an improvement, but the ultimate has to be S/PDIF out with an external DAC or processor. The one disadvantage of that approach is that you must do the volume control after the DAC, unless you don't mind giving up resolution by turning it down volume before the audio comes out of the PC.
    One solution would be a switched attenuator between the DAC and crossover so you can keep the PC volume slider high under normal listening conditions, then kick the maximum volume up 10 or 20 dB when you need to get stupid. This of course should be done using a massive industrial control switch under a lockable plexiglass cover framed by black and yellow warning stripes and with a "Hearing Protection Required" safety sticker.
    You could use a double-pole relay so the switch only switches DC and the wiring between the DAC and crossover is as short as possible.
  2. #12
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by BassBinDevil View Post
    there are some good usb solutions though; namely a usb dac. sure you have some jitter issues but for some it may be a great solution.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  3. #13
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    In terms of power, you are correct. Some PCI cards are adding good capacitance to smooth out the dirty voltage. One advantage external has over PCI is that it can help eliminate EMI from the computer. I had a card once that picked up harddrive noise IF the IDE cable is too close. It's rare, but it can happen.
  1. PCI or USB notebook PC card adapter exist?
    By kandyman676 in forum General Hardware Discussion
    Last Post: 01-21-2005, 11:57 PM
  2. Via M Series Onboard Sound vs. Audigy 2 USB
    By leenas in forum General Hardware Discussion
    Last Post: 03-10-2004, 02:53 AM
  3. Replies: 1
    Last Post: 12-27-2003, 11:27 PM
  4. USB Sound Card with ASIO driver and volume control
    By tbdombrosky in forum General Hardware Discussion
    Last Post: 02-03-2003, 11:00 PM
  5. onboard audio sucks
    By spyhunter in forum General Hardware Discussion
    Last Post: 08-17-2002, 10:41 AM
