Hey I also have a panasonic HU, with sane ports on the back, you can't connect them directly to and source for it to work as an aux port. I searched a lot to see if there was any way that I could keep my HU and use it but "NO", the rca for the cd changer only work for a panasonice cd changer that also gets plugged into the other connection, couldnt find a way around it, I wish someone on here comes up with a way to do it.
The pre amp out's can be used but then since they are rear preamp outs, your front speakers will still play whats in the cd or the radio, I found it very frustrating, but panasonic doesnt make a aux port conversion adapter...
SO good Luck let me know if you find a way around it.
LinkBack URL
About LinkBacks
The
Admittedly it was only on one channel but I think the audio jack on the tv is mono anyway. It seems as long as a cd is playing in the changer the H/U will stay in cd mode despite the different audio feed.
