Results 1 to 3 of 3
Thread: stock ford windstar amplifier?
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    just wondering if anyone has dealt with the audio systems of a ford windstar before and can clarify this for me. while doing some unrelated searching on ebay the other day, i noticed someone had a listing for a stock '95 ford windstar amplifier. and its got to be stock since its not polished or has any funky designs like commen after market amps. and its not the actual headunit either from looking at the picture.
    but what im wondering is if its even remotely possible that our '96 windstar has this same amplifier in it seperate from the HU. becuase if so, this would completely throw my carpc amplifier problems out the window.
    Your everyday carpc geek and tech guru at your service. *bow*
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    call ford and talk to a guy in parts dept..have him look up a amp for a '95, and when he gets you the number, write it down, and then say "oops, mine is a 96, sorry" and get that number. see if they are the same.
    caution though....may or may not just "plug in" and work. Ford doesnt always installl all the same wiring in different trim levels, so if the car didnt come with an amp, it may not have the wiring either.
    2005 Ford Focus ST
    Jan 2005
    Warren, Ohio, USA
    i just found a better picture of it which also shows the connections. the guy with the ebay listing listed the product number and it resulted in this from google.
    also, i was doing some more looking and theres also a wiring harness available which apparently allows an application like a carputer to be used with the stock amp: http://www.installer-data.com/item/d...php?it=70-5510
    now only thing left to do is to actually see if this amp is in our windstar or not. according to the ebay listing its located behind the glovebox so it shouldnt be too hard to locate.
  1. Replies: 11
    Last Post: 03-15-2007, 08:16 PM
  2. Stock head unit (ford taurus)
    By frostband in forum Car Audio
    Last Post: 12-26-2004, 01:14 AM
  3. Replies: 13
    Last Post: 08-22-2004, 05:52 PM
  4. Need some help with sending audio to stock amp
    By orangewhip in forum General Hardware Discussion
    Last Post: 09-04-2003, 02:21 PM
  5. Info on stock Ford CD Player
    By twins22 in forum General Hardware Discussion
    Last Post: 10-29-1999, 09:01 AM
