Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: head unit problems
    Oct 2004
    Wheeling
    head unit problems
    my head unit was working fine and then one day it jus only play out bass.. and i have a 600 watt crossfire amp with 2 12" jl audio w3 subs with the amp turned up about half way.. any1 know whats wrong...?
    _
    Mar 2004
    Little Elm, Texas
    sounds like you have a bad connection on the back side of the deck.....either your RCAs have come loose/off or inside the deck the board has lost it's solder joints.....have you tried taking the deck out and wiggling the RCA connections?
    that is of course if you have an amp running your other speakers.
    If not then I would check all your connections at your spekers, but I don't see all of them coming loose at once......sounds like it could be the deck
    how old is it, what kind is it, etc....
    Jan Bennett
    Oct 2004
    Wheeling
    rca's are fine and the head unit harness is all connected all wires are touching..
    _
    Mar 2004
    Little Elm, Texas
    then i would wiggle it....if you wiggle it can you get some sound out of it.....now don't go and jerk it, just wiggle it a bit
    unless you have one of those radios that will let you turn off the internal radio completely......so.......what kind of deck is it?
    Jan Bennett
    Feb 2005
    i have a couple questions ....
    swap the red and white rca on the amplifier...so put the right rca on the left of the amp and put the left rca on the right of the amp...does the music swap sides or stay on the same side? also is the balance control and fader of the headunit set to center? again these sound pretty basic but they will go a FAR into letting us know whats wrong...let us know what u find out...
    Kevin
    _
    Mar 2004
    Little Elm, Texas
    it will swap sides but that wont do anything as far as the mids and highs.....it will change the subs sides but it wont get you any info on what the problem is for the rest of the system
    Jan Bennett
    Feb 2005
    i was under the assumption he had all his speakers run off the amplifier or at least some amplifier/booster in the car...
    Kevin
    Quote Originally Posted by Red GTi VR6
    Oct 2004
    Wheeling
    som1 had told me that my audio chips in my deck was fried... it was working fine one night and after a long night when i woke up that next morning it was only playin bass fomr the subs no sound at all fomr the speakers...
    _
    Mar 2004
    Little Elm, Texas
    ok - so have you tried anything that we have mentioned?
    Jan Bennett
    Oct 2004
    Wheeling
    yah ive tried all of them
  1. Sound Card and Head Unit
    By cadence117 in forum Car Audio
    Last Post: 02-12-2008, 07:34 AM
  2. Can a car-computer replace a stereo head unit?
    By CA 3000GT in forum General Hardware Discussion
    Last Post: 11-13-2006, 10:24 PM
  3. FS: Kenwood Aux In Stereo Head Unit adapter. $12.50 shipped to US.
    By LESLIEx317537 in forum Classified Archive
    Last Post: 04-27-2004, 09:14 AM
  4. EBAY: BRAND NEW Kenwood KDC-MPV8025 Head Unit
    By DarrylR in forum Classified Archive
    Last Post: 04-07-2004, 09:30 PM
  5. Need a head unit
    By EvilInside944 in forum General Hardware Discussion
    Last Post: 10-07-2002, 09:25 PM
