Results 1 to 9 of 9
Thread: Solution to PC controlled Radio
    FLAC NiN^_^NiN's Avatar
    Aug 2004
    Australia, Melbourne
    I'm curious as everyone wants headunit quality FM why not try this:
    People who are connected directly to the amps and are headunitless why not get a cheap radio headunit and then store it under the seat and have the audio going into the line in on the PC and have a relay card to short the contacts of he radio stations
    So you control the buttons pushed in software and you have each button setup for a radio station
    So say you select Nova 100 in software this sends the signal for the relays to push button 2 on the radio to switch to that station.
    This way you get Headunit Quality and the headunit can be hidden
    What do you think?
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    yeah i had an idea liek that but no one was interested. Linking headunit to car for radio
    i am going it the other way round now. I decided to buy a HU when i was originally gonna use an AMP.
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    I think it's a good idea, but I wouldnt want to drag the headunit out everytime I disconnected the battery to reset the presets, and what happens when I take a trip out of the state and I have to reset all the stations again.
    肚子笑痛了
    S60 Install
    Aug 2004
    Well on my headunit it has 6 FM stations and then it has FM2 which lets you select another 6 FM stations you could have FM1 as presets for normal then interstate can be FM2 and you can just scan back and forth to what station you like.
    If your going interstate it shouldnt be for 2 long
    You could in theory hook all buttons up and have it all mapped out
    Scouse
    I'm surprised no1 replyed its a good idea i think
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    With a bit more tinkering, you can probably do better than just pusing the buttons. It's very likely that ANY HU you crack open will have a MCU inside controlling some form of tuner IC. If you can figure out the control interface, you can subsitute your own MCU with an interface back to your PC. I have an old Kenwood deck that I started to do this with.
    Ultimately though it will be more than a small bit of work that will produce one-off hack. I decided to focus my efforts upon better things -- but it's still in the bakck of mind.
    Oct 2004
    Or you could get a USB radio dongle.
    http://www.engadget.com/entry/8143838859548140/
    Is there something wrong with them that I don't know about?
    Christopher Jastram
    http://www.livingresource.net/
    cej102937
    Maximum Bitrate Danceheaven's Avatar
    May 2002
    Essex, UK'er
    Quote Originally Posted by cjastram
    Christopher Jastram
    cej102937
    Yes unfortunatly there ****
    Reception is bad enough from standing still let alone in a moving vehicle
    same goes for most PCI type cards, or USB connected Radios / Sticks there all bad in terms of reception only good thing about them is the fact there software controlled, keep an eye out for Seth and Randos RDS unit thats what we all want and need
    Co Develper of A.I.M.E.E Automotive Intelligent Multimedia Entertainment Engine
    www.aimee.cc
    Mar 2004
    Bristol
    Quote Originally Posted by NiN^_^NiN
    Scouse
    yeah well i am full of good ideas! jsut never get round to making them happen. If making patents was easier i would have lots
    Aug 2004
    Quote Originally Posted by Scouse Monkey
    It's easy you just need the money
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
  1. How2 control CarPC from key fob....
    By NotchbackVW in forum Power Supplies
    Last Post: 09-21-2007, 06:27 PM
  2. New radio for your car pc
    By khmann002 in forum General Hardware Discussion
    Last Post: 10-10-2004, 11:46 AM
  3. DAB Radio for PC
    By Scarum in forum General Hardware Discussion
    Last Post: 09-22-2004, 03:36 AM
  4. PC car questions... please help.
    By euclide in forum Car Audio
    Last Post: 05-25-2004, 05:51 AM
