Results 1 to 10 of 12
Thread: No aux on pioneer?
    Nov 2004
    No aux on pioneer?
    Well i have a pioneer deck, deh-p740mp, and i bought the cable that turns the cd changer port into an aux port, but i cannot find a way to switch to aux.
    In the instructions it says to hit func until aux becomes available and turn it on? I tried but there is no aux button whatsoever.
    Any ideas?
    Nov 2004
    New York
    there is an option when you access the menu when the headunit is off. You have to push one of the buttons...access the menu, then scroll to aux and turn it on.
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    yeah, turn the unit off, then press and hold the function or source button untill the time comes up flashing, then use the arrow keys to get to aux on or off
    肚子笑痛了
    S60 Install
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    And if it still doesnt work then you need to . Oh nevermind you should have done that before posting.
    May 2003
    Miami, FL
    Quote Originally Posted by kickercivic1
    Chill out man we already fixed the problem.
    肚子笑痛了
    S60 Install
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    But still man...
    Tidder
    Try RevFE
    Oct 2004
    Bergamo, Italy
    Ok, Yesterday I had the same problem and after reading the pioneer manual I discovered that you have to power-off the radio and then press the function key until a message appear on the dispolay.
    Now my problem is another-one I hear the music just from the rear speakers for the radio and CD everything works fine, I tried everything but no music from all the speakers... I changed all the settings but nothing happened, I changed the RCA cable, I tried other sources .... nothing
    any idea ?
    thanks
    Nov 2004
    The pioneer manual says nothing about shutting the unit down first, so before you start running your mouth before reading up on things yourself you should consider a thought process.
    Constant Bitrate bridqer's Avatar
    Nov 2003
    Maryland/Arizona
    maskone
    Each mode has its own audio properties saved(cross overs, fade, balance, ect). Sounds like some one jacked you tuner settings. If you can't figure it out disconnect your battery to reset the radio.
    '99 F-350 Crew 7.3L~'02 F-350 Crew 7.3L~ '04 Dakota SLT+ 4.7L
    MII12000opus120~MII12000opus120~MII10000opus150
    NA~Senao dual 7.4 ant~Orinoco Gold
    Pioneer~Pioneer~PG Octane-R R5.1MT
    Xenarc, Rikaline6010, Garmin OEM16 HVS, CoPilot10
    Constant Bitrate 98EXL's Avatar
    Mar 2005
    Maryland, USA
    after you enable the aux, now you need the RCA to IP-Bus converter...about $30
    Molded Screen:
    [++++++----] 60%
    DVD & Rest of audio:
    [++++++----] 60%
    2004 Accord Coupe, Satin Silver K24 5 Speed powa!
    7" Lilliput Screen, non touch with lots of Bondo
    NTB DVD player or put XBOX in car
    My 04 Accord Picture Thread
  1. Pioneer Aux Input Pin-Out
    By Ufdah in forum General Hardware Discussion
    Last Post: 07-29-2005, 03:41 PM
  2. Pioneer 2460 Replace CD function with AUX?
    By captain caveman in forum Car Audio
    Last Post: 02-12-2005, 01:09 PM
  3. Pioneer 940MP,rb-10 aux adapter, xm radio
    By tars7 in forum Classified Archive
    Last Post: 08-21-2004, 11:15 PM
  4. pioneer aux again
    By cvi in forum General Hardware Discussion
    Last Post: 03-11-2002, 08:34 PM
  5. Pioneer Aux Adapters
    By nevb in forum General Hardware Discussion
    Last Post: 01-08-2000, 10:32 AM
