Results 1 to 7 of 7
Thread: Which Rockford amp to get??
    Oct 2004
    Canada
    Hey Guys
    Anyone have any experience with the different rockford amps?
    The new line up.
    I am also considering changing sub or maybe subs with it.
    It has to be rockford because of a great deal i can get on it.
    I was thinking either a (mono) power or fanatic amp for 500watt subs rms
    Constant Bitrate mbuchman's Avatar
    Feb 2005
    What sub(s) do you have?
    The T10001bd should be plenty for you . 500wRMS @ 4 ohm, and 1000 @ 1 ohm. They are supposedly underrated as well.
    The Punch 6001 may be good for you also, but without knowing anything other than what you posted, I couldnt really help you out (if you have a 2 ohm load, then the P6001 would be plenty. If you have a 4 ohm load, then the T10001bd would be a better choice for 500wrms. if you are thinking of getting a few more subs, then the T10001bd would be the better choice being its 1 ohm stable, assuming you would wire the subs to 1 ohm)
    Matt
    Oct 2004
    Canada
    I was considering that amp I have 1 10" HX2 but also considering geting 2 10"of the Power T1. Has anyone come across the quality of the X5.A or X series of the fanatic section.
    _
    Mar 2004
    Little Elm, Texas
    screw the Punch series....keep with the Power series.....the power series are some decent amps.....punch series was made for Best Buy and are a much lesser quality/performance amplifier/speaker line....
    Jan Bennett
    Newbie Teknoledgi's Avatar
    Jan 2005
    Gold Coast Australia
    I can't see anything wrong with the punch series, I have two P2002 amps, the print out states from the 2 x 50Watts @ 4 ohms they actually manage 84 watts, can't hear anythign wrong with them either.
    Running 1 2002 supporting power 6.5" components, 1 2002 supporting punch 6.5" Coaxial rear fill, 1 P3001 supporting 2 10" subs and 1 clarion centre speaker (seperately amped)
    Lilliput 8" Touchscreen LCD
    VIA EPIA MII-12000
    60GB 3.5" Hard Drive 5400
    512MB DDR PC2700
    DVD Drive
    802.11G Internal Wireless Card - External 5db Antenna
    100m USB Bluetooth Adapter
    Nokia N70 Phone
    GPS USB Receiver
    Centrafuse 1.6
    _
    Mar 2004
    Little Elm, Texas
    some people also wouldn't notice that a jensen amp sucks.....but they do....it's all dependent upon how your ear is tuned and your speakers (quality), etc......
    a lot of times quality goes beyond what you can see
    Jan Bennett
    Oct 2004
    Canada
    I am not going with the punch series anyways I agree the the power line is a more powerful line and i would still like to know the difference between the power line and the fanatic line
    does anyone have a fanatic mono amp??
  1. PC Motherboard to 1 amp or 2?
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  2. Replies: 3
    Last Post: 12-07-2004, 07:34 PM
  3. People with NO HeadUnit, Recommand AMP!!
    By camsgs3 in forum Newbie
    Last Post: 07-26-2004, 07:38 PM
  4. FS: Rockford Fosgate Punch 400S amp
    By SiGmA_X in forum Classified Archive
    Last Post: 01-13-2004, 02:29 PM
  5. Rockford power bd1000 amp, 2 Eclipse amps, FS
    By outragis in forum Classified Archive
    Last Post: 01-19-2003, 07:01 PM
