Well depending on the amperage you will need you could run a 4 or 8 gauges wire from the battery I recommend a 4 gauge then you can put a distribution block and make it to 2 8 gauge wires. One to the inverter and one to the amp just make sure to get the proper fuse 12" from the battery; I am using a 100AMP circuit breaker for my system just to make it easier on me.
Then you just ground it 12-18" from the amp/ inverter with the same gauge as you have from the distro block.
LinkBack URL
About LinkBacks
